Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [EMFStore/ECP] Can't add more than approx. 58.000 model elements to project
[EMFStore/ECP] Can't add more than approx. 58.000 model elements to project [message #1242992] Mon, 10 February 2014 06:06 Go to next message
I'm running a ECP (v.1.2.0) application (e3) with EMFStore (v.1.1.0) as a backend.
My current workspace project contains 57.531 EMF models and I can't add more than ~250 additional models to it, without running into "java.lang.OutOfMemoryError: GC overhead limit exceeded"-exceptions and crashing the ECP application.
I also deleted the entire workspace, re-imported my project and tried to add the models again. The exception, however; keeps on re-occurring.
When exported, the entire project-file has a size of about 55mb and I remember working with much larger projects back then with the "old" 0.9.3 EMFStore/ECP releases.
Is something messed up with my project/setup (most likely?) or did I hit a performance barrier of EMF/EMFStore/ECP?
Kind regards,
Steffen
Here is the stack trace that is printed to the console before the application crashes:
!ENTRY org.eclipse.emf.ecp.ui 4 0 2014-02-10 10:59:08.491
!MESSAGE GC overhead limit exceeded
!STACK 0
	at java.lang.AbstractStringBuilder.<init>(Unknown Source)
	at java.lang.StringBuilder.<init>(Unknown Source)
	at org.eclipse.core.runtime.Plugin.isDebugging(Plugin.java:493)
	at org.eclipse.emf.transaction.internal.Tracing.shouldTrace(Tracing.java:125)
	at org.eclipse.emf.transaction.internal.Tracing.shouldTrace(Tracing.java:137)
	at org.eclipse.emf.transaction.impl.TransactionalEditingDomainImpl.deactivate(TransactionalEditingDomainImpl.java:528)
	at org.eclipse.emf.transaction.impl.TransactionImpl.close(TransactionImpl.java:712)
	at org.eclipse.emf.transaction.impl.TransactionImpl.commit(TransactionImpl.java:474)
	at org.eclipse.emf.transaction.impl.TransactionalCommandStackImpl.doExecute(TransactionalCommandStackImpl.java:70)
	at org.eclipse.emf.transaction.impl.AbstractTransactionalCommandStack.execute(AbstractTransactionalCommandStack.java:165)
	at org.eclipse.emf.transaction.impl.AbstractTransactionalCommandStack.execute(AbstractTransactionalCommandStack.java:219)
	at org.eclipse.emf.emfstore.internal.client.transaction.EMFStoreTransactionalCommandStack.runEMFStoreCommand(EMFStoreTransactionalCommandStack.java:64)
	at org.eclipse.emf.emfstore.internal.client.transaction.EMFStoreTransactionalCommandStack.execute(EMFStoreTransactionalCommandStack.java:49)
	at org.eclipse.emf.emfstore.internal.client.model.util.AbstractEMFStoreCommand.aRun(AbstractEMFStoreCommand.java:108)
	at org.eclipse.emf.emfstore.internal.client.model.util.EMFStoreCommand.run(EMFStoreCommand.java:60)
	at org.eclipse.emf.emfstore.client.util.RunESCommand.run(RunESCommand.java:143)
	at org.eclipse.emf.ecp.emfstore.core.internal.EMFStoreProvider.fillChildren(EMFStoreProvider.java:159)
	at org.eclipse.emf.ecp.internal.core.ECPProviderRegistryImpl$ProviderDescriptor.fillChildren(ECPProviderRegistryImpl.java:213)
	at org.eclipse.emf.ecp.internal.ui.model.ECPContentProvider.fillChildren(ECPContentProvider.java:50)
	at org.eclipse.emf.ecp.internal.ui.model.ModelContentProvider.fillChildren(ModelContentProvider.java:65)
	at org.eclipse.emf.ecp.internal.ui.model.TreeContentProvider.fillChildrenDetectError(TreeContentProvider.java:193)
	at org.eclipse.emf.ecp.internal.ui.model.TreeContentProvider.getChildrenList(TreeContentProvider.java:185)
	at org.eclipse.emf.ecp.internal.ui.model.TreeContentProvider.hasChildren(TreeContentProvider.java:59)
	at org.eclipse.jface.viewers.AbstractTreeViewer.isExpandable(AbstractTreeViewer.java:2146)
	at org.eclipse.jface.viewers.TreeViewer.isExpandable(TreeViewer.java:588)
	at org.eclipse.jface.viewers.AbstractTreeViewer.isExpandable(AbstractTreeViewer.java:2176)
	at org.eclipse.jface.viewers.AbstractTreeViewer.updatePlus(AbstractTreeViewer.java:2858)
	at org.eclipse.jface.viewers.TreeViewer.updatePlus(TreeViewer.java:852)
	at org.eclipse.jface.viewers.AbstractTreeViewer.updateChildren(AbstractTreeViewer.java:2751)
	at org.eclipse.jface.viewers.AbstractTreeViewer.internalRefreshStruct(AbstractTreeViewer.java:1923)
	at org.eclipse.jface.viewers.TreeViewer.internalRefreshStruct(TreeViewer.java:721)
	at org.eclipse.jface.viewers.AbstractTreeViewer.internalRefresh(AbstractTreeViewer.java:1898)
Re: [EMFStore/ECP] Can't add more than approx. 58.000 model elements to project [message #1243010 is a reply to message #1242992] Mon, 10 February 2014 06:35 Go to previous messageGo to next message
Steffen,
How big is your heap? You can increase it with a -Xmx VM parameter.
You can edit the eclipse.ini to modify that parameter.
On 10/02/2014 12:06 PM, Steffen Lehnert wrote:
> as a backend.
> Kind regards,
> Steffen
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: [EMFStore/ECP] Can't add more than approx. 58.000 model elements to project [message #1243015 is a reply to message #1243010] Mon, 10 February 2014 06:50 Go to previous messageGo to next message
Hi Ed,
I've already increased the heapsize from 256mb to 1024mb in the eclipse.ini
I will try it again with 2048 or more...
Steffen
Re: [EMFStore/ECP] Can't add more than approx. 58.000 model elements to project [message #1243063 is a reply to message #1242992] Mon, 10 February 2014 08:16 Go to previous messageGo to next message
Hi Steffen,
there should be no "conceptional" limit here, the size is too small for
this. However, there might be a performance problem, I would guess
rather in the UI (e.g. the tree viewer), which your usage reveals.
Would it be possible to create a test case with a generic model (generic
names) which you could contribute? This would help to identify the issue.
Best Regards
Jonas
Am 10.02.2014 12:06, schrieb Steffen Lehnert:
> a backend.
> Kind regards,
> Steffen
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: [EMFStore/ECP] Can't add more than approx. 58.000 model elements to project [message #1243165 is a reply to message #1243063] Mon, 10 February 2014 11:02 Go to previous messageGo to next message
Hi Jonas,
as a test case you could use the following code snippet, which I posted in another thread: this one here (at the end of the the post).
You only have to adjust the for-loop of the "RunnableWithProgress" to create the aforementioned problem:
 monitor.beginTask("Add some elements to the project", 60000);
        for(int i = 0; i < 60000; i++)
            project.getContents().add( MyModelFactory.eINSTANCE.createMyModel() );
            monitor.worked(1);
I can reproduce this behavior with any kind of "model"; simple ones containing only a few int or string properties or complex ones, like the UML metamodel.
Only the amount of models seems to matter.
I could also provide you with my entire project as a test case.
My project is based on custom meta-models (all open source and already "published" on SourceForge) and the Java meta-model supplied by the MoDisco-project.
Would that be of any help to you?
Steffen
Jonas Helming wrote on Mon, 10 February 2014 08:16
Hi Steffen,
Best Regards
Jonas
Re: [EMFStore/ECP] Can't add more than approx. 58.000 model elements to project [message #1243826 is a reply to message #1243165] Tue, 11 February 2014 08:53 Go to previous messageGo to next message
if it works with every model, we can use the example model, we use for
all tests (bowling model). Does the issue only occur when the UI is
running or did you do this test headless?
Jonas
Am 10.02.2014 17:02, schrieb Steffen Lehnert:
> Hi Jonas,
> in another thread:
> http://www.eclipse.org/forums/index.php/mv/msg/555359/1142797/#msg_1142797.
> monitor.worked(1);
> UML metamodel.
> http://eclipse.org/MoDisco/-project.
> Steffen
>> Hi Steffen,
>> Best Regards
>> Jonas
Re: [EMFStore/ECP] Can't add more than approx. 58.000 model elements to project [message #1244794 is a reply to message #1243826] Wed, 12 February 2014 17:25 Go to previous messageGo to next message
Hi Jonas,
I'm sorry for the delayed reply!
So far I have only tested this when the UI is running using a "org.eclipse.emf.ecp.application.e3.application".
Creating the models however does not take place in the UI thread. The models are created in a thread forked with a IRunnableWithProgress and than added to an existing ECP project.
Could this then be related to a concurrency issue I've reported a few months ago:
[ECP] Modifying content of ECPProject in non-UI thread?
Steffen
Jonas Helming wrote on Tue, 11 February 2014 08:53
Jonas
[Updated on: Wed, 12 February 2014 17:47] by Moderator
Re: [EMFStore/ECP] Can't add more than approx. 58.000 model elements to project [message #1245085 is a reply to message #1244794] Thu, 13 February 2014 04:21 Go to previous messageGo to next message
yes, that is what I meant. In general, the number of model elements
should not be an issue at all. However, the case to add this huge number
at once to the root level of a project as single operations seems a
little special. Is it generally possible to wrap this into one command
or composite operation?
There are three different components which could cause the issue here:
The ECP UI, more precisely the model explorer, it has to update the
TreeViewer. As the elements are all shown on the root level, it probably
makes a difference, if the project is unfolded or not. In any case, as
the default tree viewer is not a virtual tree viewer, I think even if
you can add this amount of elements on one level, working with it, will
not be fun.
The ECP core, may be related to some change notification. However, I
would not expect the problem here.
The EMFStore client persistence. For this it would be interesting,
whether you use a shared project or a local (not-shared) project. If it
is a shared project, your changes would all be recorded. While this is
not a problem in general, at least the history and the commit/update
dialogs would not show anything understandable for the user (58.000 add
operations). This could be avoided by wrapping all your operations into
one command.
So please tell me, whether you would be able to test this without the UI
(and also with using one wrapped command) and tell me the result.
Best Regards
Jonas
Am 12.02.2014 23:25, schrieb Steffen Lehnert:
> Hi Jonas,
> I'm not quite sure what exactly you mean with "test this headless"?
> Do you mean setting up a ECP project manually and populating it with the
> models, e.g. in a unit test case?
> Regards
> Steffen
>> Hi,
>> Regards
>> Jonas
Re: [EMFStore/ECP] Can't add more than approx. 58.000 model elements to project [message #1245185 is a reply to message #1245085] Thu, 13 February 2014 07:33 Go to previous messageGo to next message
thanks for the explanations!
To answer your questions:
> For this it would be interesting, whether you use a shared project or a local (not-shared) project.
I'm using local projects that have not yet been shared.
> So please tell me, whether you would be able to test this using one wrapped command and tell me the result.
I'm using a Callable for that purpose:
Callable<Void> call = new Callable<Void>()
    public Void call() throws Exception
        // add the models in here
RunESCommand.run(call);
> So please tell me, whether you would be able to test this without the UI and tell me the result.
I set up a new JUnit test in which I created a new project and populated it with 6000 models of 20 different classes (300 instances of each class).
The whole test took 30 minutes.
During these 30 minutes, I noticed that after adding about 2700 models the performance dropped significantly.
Adding the first 2500 models was done in less than 3 minutes while adding the other half took about 27 minutes.
I've re-run this test 3 times and the results were the same.
However, there was no OutOfMemory or GC exception.
Now I will try this test again using 60k models.
I will report back in a couple of hours once the test is done...
Steffen
Re: [EMFStore/ECP] Can't add more than approx. 58.000 model elements to project [message #1245813 is a reply to message #1245185] Fri, 14 February 2014 04:56 Go to previous messageGo to next message
that already takes much to long. Could you embed this test in
ECPProjectTests in org.eclipse.emf.ecp.core.test and contribute it (open
a BR)? That would be great! You could use any instance of the
"org.eclipse.emf.emfstore.examplemodel", factory would be "BowlingFactory".
Tahnks in advance!
Jonas
Am 13.02.2014 13:33, schrieb Steffen Lehnert:
> @Override
> Steffen
Re: [EMFStore/ECP] Can't add more than approx. 58.000 model elements to project [message #1245998 is a reply to message #1245813] Fri, 14 February 2014 10:17 Go to previous messageGo to next message
Hi Jonas,
I will checkout and setup the ECP projects during the weekend.
Meanwhile, I was able to further simplify my test case while obtaining the same results.
Instead of adding any custom models, it is sufficient to add simple EClass-instances and it still takes about half an hour.
I triple-checked that there are no CPU or memory intensive processes running (all CPU cores are idling on my i7-3610QM with 16GB of RAM).
Steffen
package simpletest;
import java.util.concurrent.Callable;
import junit.framework.TestCase;
import org.eclipse.emf.ecore.EcoreFactory;
import org.eclipse.emf.ecp.core.ECPProject;
import org.eclipse.emf.ecp.core.util.ECPUtil;
import org.eclipse.emf.emfstore.client.util.RunESCommand;
import org.junit.Before;
import org.junit.Test;
public class AddingModelsTest extends TestCase
    protected ECPProject project;
    @Before
    public void setUp() throws Exception
        super.setUp();
				String providerName = "org.eclipse.emf.ecp.emfstore.provider";
		        String projectName = "TestProject";
		        project = ECPUtil.getECPProjectManager().createProject(ECPUtil.getECPProviderRegistry().getProvider(providerName), projectName, ECPUtil.createProperties());
		        project.open();
				return null;
    @Test
    public void testAddModels()
				int numModels = 6000;
		        long time = System.currentTimeMillis();
		        for(int i = 0; i < numModels; i++)
		        	project.getContents().add(EcoreFactory.eINSTANCE.createEClass());
		        	if( i%100 == 0 && i > 0 ) System.out.println(i+"/"+numModels+":"+(System.currentTimeMillis() - time)+"ms");
				return null;
Jonas Helming wrote on Fri, 14 February 2014 04:56
Tahnks in advance!
Jonas
Re: [EMFStore/ECP] Can't add more than approx. 58.000 model elements to project [message #1249432 is a reply to message #1245998] Tue, 18 February 2014 03:49 Go to previous messageGo to next message
we found a potential reason for your issue. While we are working on a
"real" solution, could you kindly try the following work-around:
Please add ECPUtil.getECPProjectManager().getProjects() before you
create the new project?
Please tell me, if this speeds up things for you.
Best regards
Jonas
Am 14.02.2014 16:17, schrieb Steffen Lehnert:
> Hi Jonas,
> the same results.
> Steffen
> package simpletest;
> @Before
> @Override
> super.setUp();
> @Override
> project =
> project.open();
> return null;
> @Test
> @Override
> time)+"ms");
> return null;
>> Hi,
>> "BowlingFactory".
>> Tahnks in advance!
>> Regards
>> Jonas
Re: [EMFStore/ECP] Can't add more than approx. 58.000 model elements to project [message #1249496 is a reply to message #1249432] Tue, 18 February 2014 04:55 Go to previous messageGo to next message
Additional note:
We did some performance tests with this case. If you add the
work-around, described in the last post (due to this Bug
https://bugs.eclipse.org/bugs/show_bug.cgi?id=428370)
adding 60k or even 600k is no performance problem at all.
Best Regards
Jonas
Am 18.02.2014 09:49, schrieb Jonas Helming:
> Best regards
> Jonas
>> Hi Jonas,
>> the same results.
>> Steffen
>> package simpletest;
>> @Before
>> @Override
>> super.setUp();
>> @Override
>> project =
>> project.open();
>> return null;
>> @Test
>> @Override
>> time)+"ms");
>> return null;
>>> Hi,
>>> "BowlingFactory".
>>> Tahnks in advance!
>>> Regards
>>> Jonas
Re: [EMFStore/ECP] Can't add more than approx. 58.000 model elements to project [message #1249497 is a reply to message #1242992] Tue, 18 February 2014 04:57 Go to previous messageGo to next message
A shortcut for everyone, who does not want to read the whole thread:
This is cause by Bug
https://bugs.eclipse.org/bugs/show_bug.cgi?id=428370 and only occurs, if
the project manager is not initialized yet. Until the bug is fixed,
calling ECPUtil.getECPProjectManager().getProjects() once before adding
elements solves the issue for us. In almost any application based on
ECP, this is already called on start-up (e.g. by the model explorer)
We did some performance tests with this case. Adding 60k or even 600k is
Best Regards
Jonas
> a backend.
> Kind regards,
> Steffen
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: [EMFStore/ECP] Can't add more than approx. 58.000 model elements to project [message #1249543 is a reply to message #1249432] Tue, 18 February 2014 05:56 Go to previous messageGo to next message
Hi Jonas,
thank you very much for investigating this issue!
I applied your work-around on my unit tests and they work like a charm now.
As you said, there is no difference between adding 6000, 60k or even 600k for me either.
Thanks again!
Best regards
Steffen
Jonas Helming wrote on Tue, 18 February 2014 03:49
Best regards
Jonas
Re: [EMFStore/ECP] Can't add more than approx. 58.000 model elements to project [message #1249636 is a reply to message #1249543] Tue, 18 February 2014 08:10 Go to previous message
Please watch https://bugs.eclipse.org/bugs/show_bug.cgi?id=428370
to remove the work-arounf, once it is fixed...
Am 18.02.2014 11:56, schrieb Steffen Lehnert:
> Hi Jonas,
> 600k for me either.
> Thanks again!
> Best regards
> Steffen
>> Hi,
>> Best regards
>> Jonas
Previous Topic:How can i set save option for element as QualifiedName ?
Next Topic:[Teneo] How to get the audit history of a deleted entity?
Current Time: Thu Jul 24 22:24:40 EDT 2025
Powered by FUDForum. Page generated in 0.06880 seconds
