Home » Eclipse Projects » GEF » Cannot set Factory on ConnectionCreationTool
Cannot set Factory on ConnectionCreationTool [message #12239] Mon, 08 July 2002 08:17 Go to next message
I cannot set Factory on ConnectionCreationTool, my version of GEF is 1.0,
have you added it in GEF 2.0?
If you set the Factory on the ConnectionCreationTool, it should provide the
new Type and instance information to the request.
Someone at IBM requested this about 6 months ago so I believe it should
work.
"Jun Zhu" <zhujun@cn.ibm.com> wrote in message
news:af18ep$8tc$1@rogue.oti.com...
> I want to support 2 kinds of connection, and each kind of connection has
> its own kind of EditPart, and I add the 2 connection tools to the palette
> with the following code
> tool = new DefaultPaletteToolEntry(
> new ConnectionTool(),
> "connection1",
> "connection1",
> Image16,
> Image32
> entries.add(tool);
> "connection2",
> "connection2",
> Image16,
> Image32
> entries.add(tool);
> However, in the NodeEditPolicy.getConnectionCreateCommand(request) method,
> request.getNewObject and request.getNewObjectType all returns null, so
> that I cannot distinguish which kind of connection to create
> The current solution is to keep reference of the two new ConnectionTool in
> the above code as connection1Tool and connection2Tool, and then at the
> NodeEditPolicy.getConnectionCreateCommand(request) method, I can determine
> which kind of connection to create by testing which tool is the current
> active tool get from
> getHost().getRoot().getViewer().getEditDomain().getActiveToo l()
> Obvious this is not a good solution because of the more tight coupling
> degree between editpolicies and palettes. So I want to know why
> request.getNewObject and request.getNewObjectType will be null? Is it a
> bug? Or is there any other way of solving this problem
Re: Cannot set Factory on ConnectionCreationTool [message #12489 is a reply to message #12239] Mon, 08 July 2002 13:20 Go to previous messageGo to next message
Originally posted by: none.ibm.com
What do you mean 1.0? Where did you get 1.0? WSAD?
news:agbvt9$783$1@rogue.oti.com...
the
> work.
palette
> > "connection1",
> > "connection1",
> > Image16,
> > Image32
> > entries.add(tool);
> > "connection2",
> > "connection2",
> > Image16,
> > Image32
> > entries.add(tool);
method,
in
determine
Re: Cannot set Factory on ConnectionCreationTool [message #12571 is a reply to message #12489] Mon, 08 July 2002 22:15 Go to previous messageGo to next message
I mean GEF 1.0 which is embeded in the WSAD 4.11 IE version.
And I get the documents of GEF 1.0 from an internal site of IBM.
> the
> > work.
> palette
> > > "connection1",
> > > "connection1",
> > > Image16,
> > > Image32
> > > entries.add(tool);
> > > "connection2",
> > > "connection2",
> > > Image16,
> > > Image32
> > > entries.add(tool);
> method,
> in
> determine
Re: Cannot set Factory on ConnectionCreationTool [message #12658 is a reply to message #12571] Tue, 09 July 2002 11:28 Go to previous message
Ok. this didn't work in 1.0. No one was trying to do this, or if they did,
they were subclassing our tool instead of reporting the bug.
You can probably workaround this in 1.0. You might have to override the
conneciton tool's createRequest method, and set the factory on the request.
Sorry, I don't have 1.0 code installed right now.
news:agdgv5$3vo$1@rogue.oti.com...
1.0,
provide
> > the
should
> > > work.
has
> > palette
> > > > "connection1",
> > > > "connection1",
> > > > Image16,
> > > > Image32
> > > > entries.add(tool);
> > > > "connection2",
> > > > "connection2",
> > > > Image16,
> > > > Image32
> > > > entries.add(tool);
> > method,
so
ConnectionTool
> > in
the
> > determine
current
coupling
it a
Previous Topic:[SWT] Any support or porting projects for OS2?
Next Topic:Shape Example HOWTO
Current Time: Wed Nov 05 06:55:52 EST 2025
Powered by FUDForum. Page generated in 0.03993 seconds
