Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [EMFStore] Basic EMFStore Example doesn't work
[EMFStore] Basic EMFStore Example doesn't work [message #1248745] Mon, 17 February 2014 11:13 Go to next message
Hey guys,
I just tried to get the Basic EMFStore Example to work, but it crashes
with the following exception:
Connection to Server failed!
org.eclipse.emf.emfstore.internal.server.exceptions.ConnectionException:
Server could not be reached.
Failed to read server's response: Unrecognized SSL message, plaintext
connection?
at
org.eclipse.emf.emfstore.internal.client.model.connectionmanager.xmlrpc.XmlRpcClientManager.executeCall(XmlRpcClientManager.java:169)
at
org.eclipse.emf.emfstore.internal.client.model.connectionmanager.xmlrpc.XmlRpcClientManager.callWithResult(XmlRpcClientManager.java:115)
at
org.eclipse.emf.emfstore.internal.client.model.connectionmanager.xmlrpc.XmlRpcConnectionManager.logIn(XmlRpcConnectionManager.java:61)
at
org.eclipse.emf.emfstore.internal.client.model.impl.UsersessionImpl.logIn(UsersessionImpl.java:605)
at
org.eclipse.emf.emfstore.internal.client.model.impl.api.ESServerImpl$5.doRun(ESServerImpl.java:225)
at
org.eclipse.emf.emfstore.internal.client.model.util.EMFStoreCommand.commandBody(EMFStoreCommand.java:51)
at
org.eclipse.emf.emfstore.internal.client.model.util.AbstractEMFStoreCommand.execute(AbstractEMFStoreCommand.java:64)
at
org.eclipse.emf.common.command.BasicCommandStack.execute(BasicCommandStack.java:78)
at
org.eclipse.emf.emfstore.internal.client.model.changeTracking.commands.EMFStoreBasicCommandStack.execute(EMFStoreBasicCommandStack.java:72)
at
org.eclipse.emf.emfstore.internal.client.model.util.AbstractEMFStoreCommand.aRun(AbstractEMFStoreCommand.java:108)
at
org.eclipse.emf.emfstore.internal.client.model.util.EMFStoreCommand.run(EMFStoreCommand.java:60)
at
org.eclipse.emf.emfstore.internal.client.model.impl.api.ESServerImpl.login(ESServerImpl.java:234)
at
org.eclipse.emf.emfstore.example.helloworld.Application.runClient(Application.java:109)
at
org.eclipse.emf.emfstore.example.helloworld.Application.start(Application.java:49)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:354)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:181)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:636)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:591)
at org.eclipse.equinox.launcher.Main.run(Main.java:1450)
at org.eclipse.equinox.launcher.Main.main(Main.java:1426)
Caused by: org.apache.xmlrpc.XmlRpcException: Failed to read server's
response: Unrecognized SSL message, plaintext connection?
at
org.apache.xmlrpc.client.XmlRpcStreamTransport.sendRequest(XmlRpcStreamTransport.java:161)
at
org.apache.xmlrpc.client.XmlRpcHttpTransport.sendRequest(XmlRpcHttpTransport.java:143)
at
org.apache.xmlrpc.client.XmlRpcSunHttpTransport.sendRequest(XmlRpcSunHttpTransport.java:69)
at
org.apache.xmlrpc.client.XmlRpcClientWorker.execute(XmlRpcClientWorker.java:56)
at org.apache.xmlrpc.client.XmlRpcClient.execute(XmlRpcClient.java:167)
at org.apache.xmlrpc.client.XmlRpcClient.execute(XmlRpcClient.java:137)
at org.apache.xmlrpc.client.XmlRpcClient.execute(XmlRpcClient.java:126)
at
org.eclipse.emf.emfstore.internal.client.model.connectionmanager.xmlrpc.XmlRpcClientManager.executeCall(XmlRpcClientManager.java:159)
... 26 more
Caused by: javax.net.ssl.SSLException: Unrecognized SSL message,
at sun.security.ssl.InputRecord.handleUnknownRecord(Unknown Source)
at sun.security.ssl.InputRecord.read(Unknown Source)
at sun.security.ssl.SSLSocketImpl.readRecord(Unknown Source)
at sun.security.ssl.SSLSocketImpl.performInitialHandshake(Unknown Source)
at sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source)
at sun.net.www.protocol.https.HttpsClient.afterConnect(Unknown Source)
at
sun.net.www.protocol.https.AbstractDelegateHttpsURLConnection.connect(Unknown
Source)
at sun.net.www.protocol.http.HttpURLConnection.getOutputStream(Unknown
Source)
at
sun.net.www.protocol.https.HttpsURLConnectionImpl.getOutputStream(Unknown Source)
at
org.apache.xmlrpc.client.XmlRpcSunHttpTransport.writeRequest(XmlRpcSunHttpTransport.java:104)
at
org.apache.xmlrpc.client.XmlRpcStreamTransport.sendRequest(XmlRpcStreamTransport.java:151)
... 33 more
Seems like the call to
ESUsersession usersession = server.login("super", "super");
is the cause. Do I have to do anything else in order to make this work?
Some SSL settings in the eclipse IDE or anywhere else?
Marina
Re: [EMFStore] Basic EMFStore Example doesn't work [message #1248761 is a reply to message #1248745] Mon, 17 February 2014 11:35 Go to previous messageGo to next message
Solved. Stupid me. The server wasn't running because I had a JIRA
instance running on port 8080. Stopped the JIRA service and now it works.
BUT: when I change the port in the es.properties file to 443, it doesn't
work. I don't want to shut down my JIRA server each time I test the
Local EMFStore. Any hints on that?
New Exception is the following:
failed!org.eclipse.emf.emfstore.internal.server.exceptions.ConnectionException:
Failed to read server's response: Connection refused: connect
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
... 26 more
Caused by: java.net.ConnectException: Connection refused: connect
at java.net.DualStackPlainSocketImpl.waitForConnect(Native Method)
at java.net.DualStackPlainSocketImpl.socketConnect(Unknown Source)
at java.net.AbstractPlainSocketImpl.doConnect(Unknown Source)
at java.net.AbstractPlainSocketImpl.connectToAddress(Unknown Source)
at java.net.AbstractPlainSocketImpl.connect(Unknown Source)
at java.net.PlainSocketImpl.connect(Unknown Source)
at java.net.SocksSocketImpl.connect(Unknown Source)
at java.net.Socket.connect(Unknown Source)
at sun.security.ssl.SSLSocketImpl.connect(Unknown Source)
at sun.net.NetworkClient.doConnect(Unknown Source)
at sun.net.www.http.HttpClient.openServer(Unknown Source)
at sun.net.www.protocol.https.HttpsClient.<init>(Unknown Source)
at sun.net.www.protocol.https.HttpsClient.New(Unknown Source)
at
sun.net.www.protocol.https.AbstractDelegateHttpsURLConnection.getNewHttpClient(Unknown
Source)
at sun.net.www.protocol.http.HttpURLConnection.plainConnect(Unknown Source)
at
Source)
Source)
at
at
at
... 33 more
Am 17.02.2014 17:13, schrieb Marina Knieling:
> Hey guys,
> connection?
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 26 more
> Source)
> at
> Source)
> at
> sun.net.www.protocol.http.HttpURLConnection.getOutputStream(Unknown Source)
> at
> at
> at
> ... 33 more
> Regards
> Marina
Re: [EMFStore] Basic EMFStore Example doesn't work [message #1249464 is a reply to message #1248761] Tue, 18 February 2014 04:20 Go to previous messageGo to next message
Hi Marina,
you need to change the port of your server reference that is returned by
createAndStartLocalServer(). Otherwise the default port 8080 will be
used. After you started the server with
final ESServer localServer = ESServer.FACTORY.createAndStartLocalServer();
call setPort(PORT) on your localServer instance:
localServer.setPort(443);
This will make the client use port 443 to communicate with the server.
Note that by default Skype blocks 443.
Hope this helps.
Edgar
Am 17.02.2014 17:35, schrieb Marina Knieling:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 26 more
> at
> Source)
> Source)
> at
> Source)
> at
> at
> at
> at
> ... 33 more
>> Hey guys,
>> connection?
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> ... 26 more
>> Source)
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> at
>> ... 33 more
>> Regards
>> Marina
Edgar Mueller
Get Professional Eclipse Support: http://eclipsesource.com/munich
Re: [EMFStore] Basic EMFStore Example doesn't work [message #1250771 is a reply to message #1249464] Wed, 19 February 2014 10:30 Go to previous messageGo to next message
Hi Edgar,
thanks for your help. Works like a charm now.
Do you know of any way to set the port dynamically by finding out which
ports are used locally and then choose one that is free?
Although I think that there might be a problem with setting the port in
the es.properties file. Or can the port be set via eclipse Preferences
maybe? Any idea?
Marina
Am 18.02.2014 10:20, schrieb Edgar Mueller:
> Hi Marina,
> Hope this helps.
> Cheers,
> Edgar
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> ... 26 more
>> at
>> Source)
>> Source)
>> at
>> Source)
>> at
>> at
>> at
>> at
>> ... 33 more
>>> Hey guys,
>>> connection?
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> ... 26 more
>>> Source)
>>> Source)
>>> at
>>> Source)
>>> at
>>> Source)
>>> at
>>> Source)
>>> at
>>> at
>>> ... 33 more
>>> Regards
>>> Marina
Re: [EMFStore] Basic EMFStore Example doesn't work [message #1251574 is a reply to message #1250771] Thu, 20 February 2014 06:11 Go to previous message
Hi Marina,
I'm not sure if I understand you correctly. Would you like to set the
port of the server dynamically at startup, e.g. by starting the server
programatically and specifying the port as a parameter (instead of
declaring it in the es.properties file)? Unfortunately that is currently
not possible with EMFStore, although it would be feasible of course.
If this requirement is crucial for you, please open up a feature
request. Contributions are also welcome :)
Edgar
Am 19.02.2014 16:30, schrieb Marina Knieling:
> Hi Edgar,
> maybe? Any idea?
> Marina
>> Hi Marina,
>> Hope this helps.
>> Cheers,
>> Edgar
>>> works.
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> ... 26 more
>>> Source)
>>> at
>>> Source)
>>> Source)
>>> at
>>> Source)
>>> at
>>> Source)
>>> at
>>> Source)
>>> at
>>> at
>>> ... 33 more
>>>> Hey guys,
>>>> connection?
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> Source)
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> ... 26 more
>>>> Source)
>>>> Source)
>>>> Source)
>>>> at
>>>> Source)
>>>> at
>>>> Source)
>>>> at
>>>> Source)
>>>> at
>>>> at
>>>> ... 33 more
>>>> Regards
>>>> Marina
Edgar Mueller
Previous Topic:TENEO LONGTEXT DATATYPE
Next Topic:[EMFStore]ResourcePersister throws NotSerializableException before commit
Current Time: Fri Jul 25 09:09:18 EDT 2025
Powered by FUDForum. Page generated in 0.08084 seconds
