Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » ECP/ EMF Forms , wordwrap in text widgets
ECP/ EMF Forms , wordwrap in text widgets [message #1248666] |
Mon, 17 February 2014 09:23  |
does anyone know if it is possible to have wordwrap in the widgets displaying lots of text in EMF Forms. It seems to be that the standard widgets supplied for showing text attributes in the RCP and RAP version of ECP are always as wide as the longest line of my multi-line text. So if I have a sentence that is 400 characters long, then my text widget is 400 characters wide which makes it difficult to read.
I tried using some vertical and horizontal layouts, but this didn't solve my problem.
Maybe there is anther way to do it with layouts/spans, or maybe I can create a custom widget for this. I am particularly interested in this working with the RAP version of ECP.
Neil
Re: ECP/ EMF Forms , wordwrap in text widgets [message #1249487 is a reply to message #1248666] |
Tue, 18 February 2014 04:48   |
thank you for the report, we can reproduce this:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=428397
A work-Around would be to regsiter your own control:
http://eclipsesource.com/blogs/tutorials/how-to-customize-emf-forms/#customizecontrols
However, it would be great to receive a contribution for this BR, too.
Best Regards
Jonas
Am 17.02.2014 15:23, schrieb Neil Mackenzie:
> Hello,
> solve my problem.
> working with the RAP version of ECP. Thanks,
> Neil
Re: ECP/ EMF Forms , wordwrap in text widgets [message #1249851 is a reply to message #1249487] |
Tue, 18 February 2014 12:55   |
I will have a look into finding the problem,I suspect its to do with settings such as SWT.SINGLE and/or similar on the Text widgets
I have the source code from git for branch release_1.20
It is fairly clear how to compile it and run the code for the RCP version, I have few questions about working with the source code for RAP,
1.)For RAP should I compile against the ECP_RAP target? This is currently pointing to EMFStore 1.0 and not 1.1, and doesn't allow everything to compile, but maybe it allows enough o compile to run ECP on RAP?)
2.)Should I launch with the rap2 run configuration from git, is this kept up to date?
3.) Should the 1.2 branch always compile and run fro RAP, or is it sometimes less stable
4.) is there a way get the state of the code as it was released for RC1, RC2 etc.
Neil
Re: ECP/ EMF Forms , wordwrap in text widgets [message #1250447 is a reply to message #1249851] |
Wed, 19 February 2014 03:51   |
Before I can answer your questions: which branch have you checked out?
on master you always find the latest release (1.1.1) on develop you will
find the latest state. The sources of the RC for 1.2.0 can be found in
this branch: release_1.2.0
Best regards
Jonas
Am 18.02.2014 18:55, schrieb Neil Mackenzie:
> on RAP?)
> kept up to date?
> RC1, RC2 etc.
> Neil
Re: ECP/ EMF Forms , wordwrap in text widgets [message #1251539 is a reply to message #1250634] |
Thu, 20 February 2014 05:20   |
Neil, once you have found out exactly what you need, please consider to
file a bug report. Please let me know, if there are any open questions...
Am 19.02.2014 13:36, schrieb Neil Mackenzie:
> I havent teted this on RAP yet btw.
> Multiline I found I can set in my .genmodel file.
> It appears that the change is indeed only needed in
> getTextWidgetLayoutData()
> It looks like this change would mean that the text area never gets less
> width than 200, which is ok for me, dont know about other users,
> something like 50 might be better.
> Regards,
> Neil
Re: ECP/ EMF Forms , wordwrap in text widgets [message #1251695 is a reply to message #1251539] |
Thu, 20 February 2014 08:51  |
thanks, I have updated the bug report for the multiline wordrap issue.
I cannot test my change yet on RAP as I cant launch a working RAP app from the release 1.2 branch (for which I have raised Bug 428647 - Cannot launch RAP with supplied ecpRapDemo launch script)
Current Time: Fri Jul 25 23:42:49 EDT 2025
Powered by FUDForum. Page generated in 0.06547 seconds
