Home » Eclipse Projects » Eclipse 4 » dynamic command parameter and converter(register converter in eclipse 4)
dynamic command parameter and converter [message #1245011] Thu, 13 February 2014 01:51 Go to next message
I want to define dynamic a MHandledMenuItem with corresponding command and parameter. After seen the problem (bug 383403) I searched with EModelService my windows and could attach my menu items.
On the command side I have a problem. Defining commands and parameters is okay. But I can't see where to register my converter. What is the pure Eclipse 4 way? If I use the extension point eclipse.org.ui.commands - I use the compatibility layer, right? If I don't want to use it what's the pure eclipse 4 way?
Thx for any help
Beat
Re: dynamic command parameter and converter [message #1248385 is a reply to message #1245011] Mon, 17 February 2014 02:40 Go to previous messageGo to next message
If I want to use converters and parameters in my commands I can't do it. Why can't we define the converter in the model editor (like in the extension point)? There is only a possibility to define a typeId but no converter. So only default String converters are supported.
Beat
Re: dynamic command parameter and converter [message #1248442 is a reply to message #1248385] Mon, 17 February 2014 04:05 Go to previous messageGo to next message
IIRC the underlying system is that old one, so if you define a
commandParameterType using the old extension point it will be used!
Tom
> Beat
Re: dynamic command parameter and converter [message #1248531 is a reply to message #1248442] Mon, 17 February 2014 06:11 Go to previous messageGo to next message
Thank you Tom for the reply. As we have a big pure e4 Application I don't want just for this reason to add org.eclipse.ui.commands (needs compatibility layer, correct?).
I tried to define a command in the model with just the TypeId and then to modify it dynamic:
final Map<String, Object> commandParameters = new HashMap<String, Object>();
     final ParameterizedCommand command = commandService.createCommand(ModelIdConstants.COMMAND_PROFIL_ACTIVATE, commandParameters);
     final ParameterType type = command.getCommand().getParameterType(ModelIdConstants.COMMAND_PROFIL_PARAMETER);
     type.define(Profil.class.getCanonicalName(), converter);
     commandParameters.put(ModelIdConstants.COMMAND_PROFIL_PARAMETER, profil);
But to create the ParameterizedCommand I have to create an empty map. Otherwise I get an error because there is no converter defined.
If I make it as described I get no error but in HandlerServiceImpl I see there is an empty map. So - not parameters, an empty map. Is there another way or just the possibility to pass String parameters?
Beat
Re: dynamic command parameter and converter [message #1248568 is a reply to message #1248531] Mon, 17 February 2014 07:09 Go to previous messageGo to next message
.... well the extension point is defined in org.eclipse.ui but I guess
the parsing (see CommandPersitence!) is done by the core-bundle and the
exsd is not loaded at runtime at all.
Most likely this happened because the extension point was published
first in org.eclipse.ui and afterwards all code was moved to core.commands.
I think this is a very strange scenario so I'd suggest you file a
bugzilla so that we can discuss solutions - it simply sounds extremely
strange that you need to use an extension point which looks like it can
only be used together with the compat layer which apparently is wrong!
Tom
> Object>();
> commandParameters);
> profil);
> Beat
Re: dynamic command parameter and converter [message #1248588 is a reply to message #1248568] Mon, 17 February 2014 07:33 Go to previous message
Thanks Tom
https://bugs.eclipse.org/bugs/show_bug.cgi?id=428348
Previous Topic:Dynamic toolbar contribution
Next Topic:JFace databinding issues after migration
Current Time: Sat Jul 26 06:51:11 EDT 2025
Powered by FUDForum. Page generated in 0.25968 seconds
