Home » Modeling » EMF » Modifying EMF createPages()(How to add my own controls to createPages()?)
Modifying EMF createPages() [message #1247932] |
Sun, 16 February 2014 15:00  |
Having generated an EMF model & editor code, I want to create my own page/view and add some controls to it (combo boxes, groups, etc). How should I go about this please? My attempt is shown below, but clearly doesn't work - best I can manage is the display of one combo filling the entire view.
Do I need to create something like a view part (which I've done and laid out all my controls nicely - it's just not connected with my EMF code at all)? If it is a view part how do I link it to the EMF code (if not in createPages())?
All clues, hints, help appreciated.
Greg
* This is the method used by the framework to install your own controls.
* <!-- begin-user-doc -->
* <!-- end-user-doc -->
* @generated
public void createPages() {
// Creates the model from the editor input
createModel();
// Only creates the other pages if there is something that can be edited
if (!getEditingDomain().getResourceSet().getResources().isEmpty()) {
// Create a page .
Group grpSubject = new Group(getContainer(), SWT.NONE);
grpSubject.setLocation(0, 43);
grpSubject.setSize(219, 83);
grpSubject.setText("Subject");
// grpSubject.setLayout(new BoxLayout(BoxLayout.X_AXIS));
final Combo cmbSubject = new Combo(getContainer(), SWT.READ_ONLY);
final String osScopeItems[] = { "Product", "Customer", "Service", "Billing", "Resource", "F-P-T", "Network I/F", "Operations H/O", "B2B", "Custom" };
cmbSubject.setItems(osScopeItems);
cmbSubjectViewer = new ComboViewer(cmbSubject);
setCurrentViewer(cmbSubjectViewer);
cmbSubjectViewer.setContentProvider(new AdapterFactoryContentProvider(adapterFactory));
cmbSubjectViewer.setLabelProvider(new AdapterFactoryLabelProvider(adapterFactory));
cmbSubjectViewer.setInput(editingDomain.getResourceSet());
cmbSubjectViewer.setSelection(new StructuredSelection(editingDomain.getResourceSet().getResources().get(0)), true);
int pageIndex = addPage(grpSubject);
setPageText(pageIndex, getString("_UI_SelectionPage_label"));
int x = getActivePage();
setControl(x, cmbSubject);
DataBindingContext bindingContext = new DataBindingContext();
bindingContext.bindValue(ViewersObservables.observeSingleSelection(cmbSubjectViewer),
EMFEditObservables.observeValue(editingDomain, ContractSpecEditorPackage.eINSTANCE.getSubject(),
(EStructuralFeature) ContractSpecEditorPackage.Literals.SUBJECT));
getSite().getShell().getDisplay().asyncExec
(new Runnable() {
public void run() {
setActivePage(0);
// Ensures that this editor will only display the page's tab
// area if there are more than one page
getContainer().addControlListener
(new ControlAdapter() {
boolean guard = false;
public void controlResized(ControlEvent event) {
if (!guard) {
guard = true;
hideTabs();
guard = false;
(new Runnable() {
public void run() {
updateProblemIndication();
Re: Modifying EMF createPages() [message #1248313 is a reply to message #1247932] |
Mon, 17 February 2014 00:56   |
Greg,
On 16/02/2014 9:00 PM, Greg Dart wrote:
> the entire view.
This is more a question of how to create views using JFace, not an
EMF-specific question. To have a view with multiple things on it, you'd
need a Composite and using layouts https://wiki.eclipse.org/JFaceSnippets
You'll want to use data binding to bind something more specific than the
whole editing domain.
> Greg
> controls.
> * @generated
> @Override
> createModel();
> be edited
> if
> // Create a page .
> SWT.READ_ONLY);
> true);
I imagine this must thrown an exception given EClass (the third
argument) isn't an EStructuralFeature. You'll want to obverse some
value you get from the resource in the resource set, and you'll want to
specify a feature that value actually has.
http://www.vogella.com/tutorials/EclipseDataBindingEMF/article.html
> (new Runnable() {
> public void run() {
> setActivePage(0);
> @Override
> if (!guard) {
> guard = true;
> hideTabs();
> guard = false;
> (new Runnable() {
> public void run() {
Re: Modifying EMF createPages() [message #1248365 is a reply to message #1248313] |
Mon, 17 February 2014 02:15  |
>> the entire view.
> you'd need a Composite and using layouts
Have a look at WindowBuilder.
Ed Willink
Current Time: Wed Jul 23 16:17:24 EDT 2025
Powered by FUDForum. Page generated in 0.04279 seconds
