Home » Modeling » EMF » [Xcore] problems with "Converting a GenModel to an Xcore Model"
| [Xcore] problems with "Converting a GenModel to an Xcore Model" [message #1245520] |
Thu, 13 February 2014 18:21  |
I've just started using Xcore and I wanted to create the xcore file from
the genmodel, and I followed the documentation in the wiki page.
However, this operation never terminates successfully (I saw there are
some bugs about that but they all seem to have been solved). I also
tried by starting from the extended library example, but I get the
following exceptions upon creation of the .xcore file. The first one
appears the first time I run the export; the following times (after the
export wizard has added deps to xbase lib and xcore lib) I get a similar
exception (see the second exception). Am I doing anything wrong?
FIRST TIME:
java.lang.RuntimeException: No EObjectDescription could be found in
Scope XAnnotation.source for
XPackage'xcore.lang'.annotationDirectives[0]->XAnnotationDirective'Ecore'
Semantic Object:
XPackage'org.eclipse.emf.examples.extlibrary'.annotations[0]->XAnnotation
at
org.eclipse.xtext.serializer.diagnostic.ISerializationDiagnostic$ExceptionThrowingAcceptor.accept(ISerializationDiagnostic.java:70)
at
org.eclipse.xtext.serializer.tokens.CrossReferenceSerializer.getCrossReferenceNameFromScope(CrossReferenceSerializer.java:146)
at
org.eclipse.xtext.serializer.tokens.CrossReferenceSerializer.serializeCrossRef(CrossReferenceSerializer.java:119)
at
org.eclipse.xtext.serializer.acceptor.SequenceFeeder.getToken(SequenceFeeder.java:453)
at
org.eclipse.xtext.serializer.acceptor.SequenceFeeder.accept(SequenceFeeder.java:220)
at
org.eclipse.xtext.serializer.sequencer.BacktrackingSemanticSequencer.accept(BacktrackingSemanticSequencer.java:403)
at
org.eclipse.xtext.serializer.sequencer.BacktrackingSemanticSequencer.createSequence(BacktrackingSemanticSequencer.java:441)
at
org.eclipse.xtext.serializer.acceptor.SequenceFeeder.acceptEObjectRuleCall(SequenceFeeder.java:299)
at
org.eclipse.xtext.serializer.acceptor.SequenceFeeder.acceptRuleCall(SequenceFeeder.java:325)
at
org.eclipse.xtext.serializer.acceptor.SequenceFeeder.accept(SequenceFeeder.java:239)
at
org.eclipse.xtext.serializer.sequencer.BacktrackingSemanticSequencer.accept(BacktrackingSemanticSequencer.java:396)
at
at
org.eclipse.xtext.serializer.impl.Serializer.serialize(Serializer.java:85)
at
org.eclipse.xtext.serializer.impl.Serializer.serialize(Serializer.java:108)
at
org.eclipse.xtext.serializer.impl.Serializer.serialize(Serializer.java:130)
at org.eclipse.xtext.resource.XtextResource.doSave(XtextResource.java:344)
at
org.eclipse.emf.ecore.resource.impl.ResourceImpl.save(ResourceImpl.java:1430)
at
org.eclipse.emf.ecore.resource.impl.ResourceImpl.save(ResourceImpl.java:999)
at
org.eclipse.emf.ecore.xcore.exporter.XcoreExporter$3.run(XcoreExporter.java:417)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:53)
SECOND TIME
Scope XGenericType.type for
GenModel.genPackages[0]->GenPackage.genDataTypes[16]->GenDataType
Semantic Object:
XPackage'org.eclipse.emf.examples.extlibrary'.classifiers[1]->XClass'Library'.members[8]->XAttribute'people'.type->XGenericType
at
at
at
at
at
at
at
at
at
at
org.eclipse.xtext.serializer.acceptor.SequenceFeeder.accept(SequenceFeeder.java:222)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
HOME: http://www.lorenzobettini.it
Xtext Book:
http://www.packtpub.com/implementing-domain-specific-languages-with-xtext-and-xtend/book
| Re: [Xcore] problems with "Converting a GenModel to an Xcore Model" [message #1245680 is a reply to message #1245520] |
Fri, 14 February 2014 00:32   |
Lorenzo,
I tried this locally using the Luna version of things, and I properly
ended up with:
@Ecore(nsPrefix="extlib",
nsURI="http:///org/eclipse/emf/examples/library/extlibrary.ecore/1.0.0")
@GenModel(modelDirectory="/org.eclipse.emf.examples.library/src",
prefix="EXTLibrary", contentTypeIdentifier="extendedLibrary",
editDirectory="/org.eclipse.emf.examples.library.edit/src",
editorDirectory="/org.eclipse.emf.examples.library.editor/src",
runtimeJar="true", modelName="EXTLibrary",
editPluginClass="org.eclipse.emf.examples.extlibrary.provider.EXTLibraryEditPlugin",
editorPluginClass="org.eclipse.emf.examples.extlibrary.presentation.EXTLibraryEditorPlugin",
nonNLSMarkers="true", booleanFlagsField="eFlags",
booleanFlagsReservedBits="8",
importerID="org.eclipse.emf.importer.ecore", language="en")
package org.eclipse.emf.examples.extlibrary
import org.eclipse.emf.ecore.EFeatureMapEntry
class Book extends CirculatingItem {
String title
int pages = "100"
unsettable BookCategory category
refers Writer[1] author opposite books
class Library extends Addressable {
String name
@ExtendedMetaData(group="#people")
contains transient volatile derived Writer[] writers
contains transient volatile derived Employee[] employees
contains transient volatile derived Borrower[] borrowers
contains unordered Item[] stock
refers unordered transient derived Book[] books
contains resolving Library[] branches opposite parentBranch
container resolving Library parentBranch opposite branches
@ExtendedMetaData(kind="group")
unique EFeatureMapEntry[] people
class Writer extends Person {
transient volatile String name
refers Book[] books opposite author
enum BookCategory {
Mystery
ScienceFiction = 1
Biography = 2
abstract class Item {
java.util.Date publicationDate
interface Lendable {
int[1] copies
refers unordered Borrower[] borrowers opposite borrowed
abstract class CirculatingItem extends Item , Lendable {
abstract class Periodical extends Item {
String title
int[1] issuesPerYear
abstract class AudioVisualItem extends CirculatingItem {
String title
int[1] minutesLength
boolean damaged
class BookOnTape extends AudioVisualItem {
refers Person reader
refers Writer author
class VideoCassette extends AudioVisualItem {
refers Person[] cast
class Borrower extends Person {
refers Lendable[] borrowed opposite borrowers
class Person extends Addressable {
String[1] firstName
String[1] lastName
class Employee extends Person {
refers Employee manager
interface Addressable {
String address
Were you trying with the latest versions of EMF and Xtext?
On 14/02/2014 12:21 AM, Lorenzo Bettini wrote:
> Hi
> FIRST TIME:
> Semantic Object:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> SECOND TIME
> Semantic Object:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
| Re: [Xcore] problems with "Converting a GenModel to an Xcore Model" [message #1245976 is a reply to message #1245680] |
Fri, 14 February 2014 09:42   |
On 14/02/2014 06:32, Ed Merks wrote:
> Lorenzo,
> ended up with:
Hi Ed
I'm using the latest versions of both EMF and Xtext (but I'm still using
Kepler).
I tried with a brand new workspace and things worked this time (!), so I
guess there was something wrong in my previous workspace.
Now I'd like to know if anyone has tried to use Xcore for the metamodel
of an Xtext DSL that uses Xbase. Indeed, that's my use case: I switched
to a manually managed ecore (and genmodel) file for this DSL, and then
to Xcore. I managed to export the xcore from the genmodel now, but I
get Java compilation errors in the generated Java EPackage class (for
classes extending an Xbase class).
Should I switch to the Xtext forum?
cheers
Lorenzo
Xtext Book:
| Re: [Xcore] problems with "Converting a GenModel to an Xcore Model" [message #1245982 is a reply to message #1245976] |
Fri, 14 February 2014 09:51   |
Lorenzo,
Comments below.
>> Lorenzo,
>> ended up with:
> Hi Ed
> Kepler).
I suppose it's possible that the index had old crap in it...
Did you delete the *.genmodel? It might confuse the index to have both
a *.genmodel and *.xcore for the same nsURI...
What kind of errors? Ones caused by missing dependencies in the
MANIFEST? Or bad generated results about dependencies on other XyxPackages?
We can continue here for now if it seems like an EMF/Xcore problem...
> cheers
> Lorenzo
| Re: [Xcore] problems with "Converting a GenModel to an Xcore Model" [message #1246100 is a reply to message #1245982] |
Fri, 14 February 2014 13:16   |
Hi Ed
I'll get errors due to missing operation count in the base class; I
haven't tried to delete the genmodel (I'll try to do that later).
However, I've just noticed that also the .xcore exported in the Extended
library example generates wrong Java code. In this case I also tried to
delete the genmodel, and rebuild the project but I get several
compilation errors; for instance about the generated enumeration literals:
before xcore in BookCategory you have
MYSTERY_LITERAL(0, "Mystery", "Mystery")
but then you have
int MYSTERY = 0;
and the previous code
private static final BookCategory[] VALUES_ARRAY =
new BookCategory[]
MYSTERY_LITERAL,
SCIENCE_FICTION_LITERAL,
BIOGRAPHY_LITERAL,
is now
new BookCategory[]
MYSTERY,
SCIENCE_FICTION,
BIOGRAPHY,
and Java complains, for instance, that
Cannot make a static reference to the non-static field BIOGRAPHY
BookCategory.java
/org.eclipse.emf.examples.library/src/org/eclipse/emf/examples/extlibrary
this is the xcore that has been generated during the export, and it
looks just the same as yours...
Lorenzo
String title
int pages = "100"
String name
enum BookCategory {
Mystery
ScienceFiction = 1
Biography = 2
int[1] copies
String title
String title
boolean damaged
String[1] firstName
String[1] lastName
String address
Xtext Book:
| Re: [Xcore] problems with "Converting a GenModel to an Xcore Model" [message #1246741 is a reply to message #1246100] |
Sat, 15 February 2014 06:30   |
Lorenzo,
Comments below.
> Hi Ed
This problem arises when the GenModel specifies Reflective Operation
Invocation (the default for Xcore-based models) and the base model
specifies it as false. You can set it to false with an
@GenModel(operationReflection="false") in the *.xcore. Ideally Xbase
would specify it as true for getter client flexibility to support that
in their derived models.
> but then you have
> int MYSTERY = 0;
> new BookCategory[]
> MYSTERY_LITERAL,
> BIOGRAPHY_LITERAL,
> is now
> new BookCategory[]
> MYSTERY,
> SCIENCE_FICTION,
> BIOGRAPHY,
> BookCategory.java
You get different results for the enum depending on
@GenModel(typeSafeEnumCompatible="true") on the GenEnum. I haven't
looked closely but this must default differently for Xcore than it does
for an ordinary *.ecore based model.
So in both cases, you can work around the problem with @GenModel
annotations. Nevertheless, please open a bugzilla with a
hopefully-minimized example reproducing the problem and I'll look into
doing a better job generating the annotations automatically.
> Lorenzo
> String title
> int pages = "100"
> String name
> enum BookCategory {
> Mystery
> ScienceFiction = 1
> Biography = 2
> int[1] copies
> String title
> String title
> boolean damaged
> String[1] firstName
> String[1] lastName
> String address
Current Time: Sun Nov 02 19:29:13 EST 2025
Powered by FUDForum. Page generated in 0.05097 seconds
