Home » Archived » Test and Performance Tools Platform (TPTP) » Behaviour Tab missing
Behaviour Tab missing [message #124436] Tue, 26 February 2008 10:33 Go to next message
I am using eclipse 3.2.2 with TPTP Test 4.2.3 and successfully imported a
J Unit Test into TPTP J Unit Test using the steps below.
File > Import > JUnit tests to TPTP.
Click Next to display the JUnit Tests selection dialog.
Navigate to the required files and then click on Finish.
The outcome of a successful import operation will be a TPTP JUnit Test
File associated with the imported package or class
After the import, I am seeing only the following tabs in the Test Suite.
OverView and TestCases not the "Behaviour" Tab as I see in a normal TPTP J
UnitTest.
Did I missing any thing ? Please let me know.
Saran
Re: Behaviour Tab missing [message #124563 is a reply to message #124436] Wed, 27 February 2008 06:15 Go to previous messageGo to next message
Open the overview tab and deselect 'Implement Test Behaviour as code'. This
option is selected after an import so the original JUnit test code is not
modified.
"Saran" <saravanan.subramanian@cmegroup.com> wrote in message
news:07761548a87f90d6417adae36dc9d6cf$1@www.eclipse.org...
> File > Import > JUnit tests to TPTP. Click Next to display the JUnit Tests
> selection dialog. Navigate to the required files and then click on Finish.
> UnitTest.
> Thanks
> Saran
Re: Behaviour Tab missing [message #124779 is a reply to message #124563] Thu, 28 February 2008 15:26 Go to previous messageGo to next message
Hi ,
I am dont see the option you mentioned. In the overview tab, I am seeing
only the following .
General Information
Test Objective - a drop down
Test Cases
Data Pool.
Am I missing any thing, because I have to see the behaviour tab so that I
can change the execution order of the test cases.
Saran
Re: Behaviour Tab missing [message #124803 is a reply to message #124779] Fri, 29 February 2008 07:21 Go to previous messageGo to next message
It appears that your installation is not complete. The editor you are
seeing is a general editor, not the JUnit editor. Are there any errors in
the .log file?
PS
news:e4baba35460fd3d6c107b873d0231452$1@www.eclipse.org...
> Hi ,
> General Information
> Test Cases Data Pool.
> Thanks
> Saran
Re: Behaviour Tab missing [message #124816 is a reply to message #124803] Fri, 29 February 2008 07:21 Go to previous messageGo to next message
If there are not errors, can you provide a listing of the installed
plug-ins?
PS
"Paul Slauenwhite" <paules@ca.ibm.com> wrote in message
news:fq8tbo$o04$1@build.eclipse.org...
> the .log file?
> PS
>> Hi ,
>> General Information
>> Thanks
>> Saran
Re: Behaviour Tab missing [message #124911 is a reply to message #124816] Fri, 29 February 2008 10:51 Go to previous messageGo to next message
Hi Paul,
Thanks for your input, After I switched back to the J Unit Test Definition
Editor as my default editor then I am able to see the behaviour tab as per
your input in the earlier email.
But after changing the testsuite to execute only one method(loop and
execution) using the behaviour tab , I dont see the code necessary for the
above or the TPTP Junit code is incorporated into the J Unit Test.
The J unit Test is not modified at all even after converting it into TPTP
J Unit Test.
Other than Importing the J unit into TPTP J Unit, Do I have to do any
thing in addition for the conversion to work proper please let me know .
Saran
Re: Behaviour Tab missing [message #125090 is a reply to message #124911] Mon, 03 March 2008 06:39 Go to previous message
When the JUnit test suite is saved after changing the behaviour, the code
generator will modify your JUnit test code. A code change preview dialog is
always shown. It sounds like have done all of the steps, but might be
working a bad installation. Can you download and try the latest release of
TPTP:
http://www.eclipse.org/tptp/home/downloads/
PS
news:421459638389e61453388fc9116fef95$1@www.eclipse.org...
> Hi Paul,
> J Unit Test.
> Thanks
> Saran
Previous Topic:Information about tptp
Next Topic:Is timeline preserved within TPTPs?
Current Time: Sat Jul 26 23:17:58 EDT 2025
Powered by FUDForum. Page generated in 0.25723 seconds
