Home » Eclipse Projects » Rich Client Platform (RCP) » fragment.e4xmi perspective does not show specified icon
fragment.e4xmi perspective does not show specified icon [message #1091563] Wed, 21 August 2013 13:05 Go to next message
I am using eclipse 4.2 as RCP and defined a perspective in a fragment.e4xmi. All works well except
the defined icon is not shown but the default icon.
Is there any restriction of size or icon type?
I am using a 16px by 16px png file.
Any other idea how to get this right?
thanks in advance, Martin
Re: fragment.e4xmi perspective does not show specified icon [message #1245536 is a reply to message #1091563] Thu, 13 February 2014 18:57 Go to previous messageGo to next message
Hi Martin,
I am experiencing similar problem in Eclipse 4.3.1. The icon in my defined perspective always shows as a default icon. The same plug-in in Eclipse 3.7 shows the customized icon correctly.
I tried to reproduce this problem in a simple plug-in, but it works correctly.
Can you please let me know, if you were able to find a solution for this problem?
Thank you,
Ed
Re: fragment.e4xmi perspective does not show specified icon [message #1250305 is a reply to message #1245536] Wed, 19 February 2014 00:25 Go to previous messageGo to next message
Hi Ed,
no I did not find a solution. Its still displaying the default icon.
Would be interested if you can find some thing.
Martin
schrieb Ed Yarve, Am 14.02.2014 14:51:
> Hi Martin,
> Thank you,
> Ed
Re: fragment.e4xmi perspective does not show specified icon [message #1251197 is a reply to message #1250305] Wed, 19 February 2014 20:41 Go to previous messageGo to next message
Thank you for the answer.
I decided to debug the internal Eclipse code which initializes the PerspectiveDescriptor from plug-in registry. I found that image is never populated in the descriptor. The initialization of the image is done while requesting the image by PerspectiveDescriptor.getImageDescriptor() method, when it called for the first time. This method uses IConfigurationElement.getNamespaceIdentifier() to find a plug-in to retrieve the icon from. In my case the returned identifier was not correct. If my plug-in was named "com.xyz.bugs.icon.myplugin", the returned identifier was only "com.xyz.bugs".
The following extension will show the default icon, instead of icons/sample.gif.
   <extension
         id="com.xyz.bugs.perspectives"
         name="xyz"
         point="org.eclipse.ui.perspectives">
      <perspective
            class="com.xyz.bugs.icon.PerspectiveFactory"
            icon="icons/sample.gif"
            id="com.xyz.bugs.icon.MyPerspective"
            name="xyz perspective">
      </perspective>
   </extension>
If the extension id would be "com.xyz.bugs.icon.perspectives" it would actually work fine, as it looks like Eclipse removes the last component "perspectives" and treats the rest as a plugin to retrieve the icon from. I did not find this in documentation, so i think it is a bug.
Another way to solve the issue is to remove id from the extension:
   <extension
         name="xyz"
      <perspective
      </perspective>
   </extension>
I was also able to reproduce this on a sample plug-in, so I can actually file a bug.
Re: fragment.e4xmi perspective does not show specified icon [message #1263137 is a reply to message #1251197] Tue, 04 March 2014 03:08 Go to previous message
Hi Ed,
thanks for your investigations! I will try it in coming days and looking forward to fix this bug.
But for now I will try your workarounds, Martin
schrieb Ed Yarve, Am 20.02.2014 02:41:
> <extension
> name="xyz"
> <perspective
> </perspective>
> </extension>
> <extension
> name="xyz"
> <perspective
> </perspective>
> </extension>
Previous Topic:How to interactively waiting for background jobs? [solved]
Next Topic:(eclipse rcp 3.x) No view-elements displayed when launching via .product
Current Time: Sat Jul 26 19:10:27 EDT 2025
Powered by FUDForum. Page generated in 0.04393 seconds
