| Using XML Datasource for RCP [message #124526] |
Mon, 06 February 2006 01:22 |
Originally posted by: calltl.hotmail.com
Hi all,
I am currently testing BIRT with my RCP application. Report generation is
done by combining an automatically generated XML file (as data source) and a
predefinited BIRT design file (which understand the structure of the XML
data source).
Since BIRT designer hardcoded the XML data source file (in absolute path)
during report design phase, I need to reset the XML data source filename
just before RCP generates the report via BIRT API.
When I examine the code from org.eclipse.birt.report.data.oda.xml, I realise
the data source filename is stored in DataSourceHandle. Hence I believe I
can retrieve the information from IReportRunnable.getDesignHandle() after I'
ve opened the report design from RCP. However, I cannot find any
information on data source.
Is there any API that I can call to get and set the XML data source filename
from BIRT API? Please help. Thanks.
Tony Lam
Australian Nuclear Science and Technology Organisation
PMB 1, Menai NSW 2234
FUDForum. Page generated in 0.03465 seconds
