Home » Archived » Hudson » SvnTag plugin doesn't support Release plugin?(Getting message SvnTag plugin doesn't support tagging for SCM hudson.scm.SubversionReleaseSCM)
SvnTag plugin doesn't support Release plugin? [message #1244781] Wed, 12 February 2014 17:00 Go to next message
Hi All,
I'm using Subversion Release plugin and want to tag it after the build successful.
However, I'm getting below message and the tag is not being created.
SvnTag plugin doesn't support tagging for SCM hudson.scm.SubversionReleaseSCM@3a29d2f3.
I'm using Hudson v1.351 and versions of the plugins are:
Subversion Release Manager v1.1
Subversion Tagging Plugin v1.13
Any idea?
[Updated on: Thu, 13 February 2014 11:29] by Moderator
Re: SvnTag plugin doesn't support Release plugin? [message #1250744 is a reply to message #1244781] Wed, 19 February 2014 09:56 Go to previous message
Anyone tried to tag after the release plugin build?
To give you more idea on my setup, I have CI Hudson project running against code check-ins and a separate Hudson project for the deployment which I'm building manually for the revision that I want and would like to tag it automatically for that release.
Do you manually tag before release build or do you even use release plugin?
What's the best practice on this setup?
Any suggestion would be greatly appreciated.
Previous Topic:[Hudson 3.1.2 - Upgraded from 1.384] Loading Dashboard very slow & Cannot delete job.
Next Topic:Uninstall or fix Hudson on Linux
Current Time: Sat Jul 26 11:05:25 EDT 2025
Powered by FUDForum. Page generated in 0.03770 seconds
