Home » Modeling » M2T (model-to-text transformation) » [Acceleo] A switch in an Acceleo query
[Acceleo] A switch in an Acceleo query [message #1244594] Wed, 12 February 2014 10:18 Go to next message
I have to implement an Acceleo query which should return a string value based on the input. It can be implemented using an equivalent of a Java switch statement. Unfortunately, I didn't find anything similar to the switch in the specification. Acceleo/OCL doesn't support the elseif statement that's why this simple code contains many nested 'if's and its readability suffers:
    if aResponseCode = 200 then 'OK'
      else if aResponseCode = 403 then 'Forbidden'
        else if aResponseCode = 500 then 'Internal Server Error'
           else ''
        endif
      endif
    endif
A good way to implement it would be using an associative array (table), but again, it wasn't mentioned anywhere in the specification. Therefore, the only alternative to multiple nested 'if's that I can see is to use a Java service which delegates this functionality to a Java method.
Is there an equivalent of a switch or associative array in Acceleo? Can you suggest better alternatives to using nested ifs or a java helper?
Tanya
Re: [Acceleo] A switch in an Acceleo query [message #1244676 is a reply to message #1244594] Wed, 12 February 2014 13:22 Go to previous messageGo to next message
Acceleo has elif so you don't have to nest.
You can exploit the cached queries and so teach Acceleo your lookups, so
the slow if chain only gets executed once per value.
However you'll find that learning to call out to Java is often helpful
for hard problems.
Ed Willink
On 12/02/2014 15:18, Tatiana Fesenko wrote:
> Hi, I have to implement an Acceleo query which should return a string
> if aResponseCode = 200 then 'OK' else if aResponseCode = 403
> then 'Forbidden' else if aResponseCode = 500 then 'Internal
> Server Error' else '' endif endif endif
> Java method.
> Tanya
Re: [Acceleo] A switch in an Acceleo query [message #1244706 is a reply to message #1244676] Wed, 12 February 2014 14:28 Go to previous messageGo to next message
I am using Acceleo 3.4.0 and it shows the '"else" expected instead of "elif"' error on an attempt to use 'elif'. I tried 'elsif' - the same result.
I believe Acceleo uses OCL for queries. The 9.4.46 section of the OCL 2.3.1 specification defines the syntax for the "if" conditions that doesn't support 'elsifs' :
IfExpCS ::= 'if' OclExpression[1]
'then' OclExpression[2]
'else' OclExpression[3]
'endif'
I try to avoid using Java helpers in Acceleo as navigating from Acceleo templates to Java code is not good for readability of the code.
Re: [Acceleo] A switch in an Acceleo query [message #1244713 is a reply to message #1244706] Wed, 12 February 2014 14:43 Go to previous messageGo to next message
HI
Acceleo has its own syntax for [if ...]...[/if] but indeed OCL for if
.... endif
Only Acceleo has elif at present, although we agreed t propose elif as
part of the OCL 2.5 submission.
Ed Willink
> result.
> Quote:
>> 'endif'
Re: [Acceleo] A switch in an Acceleo query [message #1244719 is a reply to message #1244713] Wed, 12 February 2014 14:54 Go to previous message
Ed, an "elif" would be a nice feature of OCL 2.5. Looking forward to seeing it!
Meanwhile, I'll use a Java helper for this particular situation.
Previous Topic:Change in Profile Causes Stereotype to not be found
Next Topic:Eclipse UML Profiles Repository now available!
Current Time: Sat Jul 26 21:06:51 EDT 2025
Powered by FUDForum. Page generated in 0.04924 seconds
