Home » Modeling » EMF » etypes.ecore Model in CDO Source(Why is etypes.ecore model using Ecore.ecore metamodel?)
etypes.ecore Model in CDO Source [message #1244046] |
Tue, 11 February 2014 15:58  |
CDO source has a model named etypes.ecore, which is using the development version of Ecore.ecore metamodel.
What is the purpose of doing this? Is this the way of extending Ecore to provide CDO support for .ecore models?
[Updated on: Tue, 11 February 2014 16:15] by Moderator
Re: etypes.ecore [message #1245089 is a reply to message #1244506] |
Thu, 13 February 2014 04:22   |
Am 12.02.2014 13:39, schrieb UmaShankar Subramani:
> Hi Eike,
> I am really sorry. The problem is that, my question was not clear enough.
> My question is not about using CDOMigrator. I am asking how CDO source works.
CDOObjectImpl extends EObjectImpl (more or less) and the CDO migrator modifies the GenModels to generate your model
classes as subclasses of CDOObjectImpl instead of EObjectImpl.
> Consider, I have CDO source installed on my computer. When I create an Ecore model, it works
> normally.
Do you want to say that you can save and load XML files? Or what is "normally"?
> But, when I create another Ecore model
Is that another instance of the same EPackage?
> in the runtime instance(with CDO support)
> it works under CDO. This is my question.
Actually I don't see a question here. If you want to ask if your models, when generated for CDO, can still be used with
XML persistence, then yes, they can.
> So, I believe that the functionality of Ecore itself is extended/overridden by CDO.
I suspect that you're using the term Ecore wrongly, too generally. But in some sense CDO extends Ecore because EObject
is a concept of the Ecore meta meta model.
> Where has this happened. This is my question.
All starts here:
http://git.eclipse.org/c/cdo/cdo.git/tree/plugins/org.eclipse.emf.cdo/src/org/eclipse/emf/internal/cdo/CDOObjectImpl.java
Cheers
/Eike
http://www.esc-net.de
Re: etypes.ecore [message #1247829 is a reply to message #1245089] |
Sun, 16 February 2014 12:16   |
>> Hi Eike,
>CDOObjectImpl extends EObjectImpl (more or less) and the CDO migrator modifies the >GenModels to generate your model
Okay. I understand this. But this process happens when I migrate my Ecore model using CDOMigrator. I want to know how the same thing happens when I create a new Ecore Model. How is the newly created Ecore model related to CDO. Where is this done in the plugin project org.eclipse.emf.cdo
>> Consider, I have CDO source installed on my computer. When I create an Ecore >>model, it works normally.
>Actually I don't see a question here. If you want to ask if your models, when >generated for CDO, can still be used with
If I have no CDO installed, during addition of an Ecore object, ResourceImpl.attached(EObject object) method is invoked. (This is what I call Normally)
If I have CDO installed, addition of Ecore object invokes CDOResourceImpl.attached(EObject object) method. (This is what I call-Ecore with CDO Support)
When Ecore model is created inside a CDO environment, the EObjects are created as CDOObjects.
Where is this happenning?, How the CDO classes are notified, when an Ecore model is created, when a new object is added/deleted? This is what I wanted to ask.
>> So, I believe that the functionality of Ecore itself is extended/overridden by >>CDO.
>I suspect that you're using the term Ecore wrongly, too generally. But in some sense >CDO extends Ecore because EObject
>All starts here:
Thanks. This is the most useful CDO class.
/Uma
[Updated on: Sun, 16 February 2014 12:38] by Moderator
Re: etypes.ecore [message #1247895 is a reply to message #1247829] |
Sun, 16 February 2014 14:02   |
Uma,
If your model is generated for CDO then CDOObjects are created and if it is not generated for CDO then no CDOObjects are
created.
Cheers
/Eike
Am 16.02.2014 18:16, schrieb UmaShankar Subramani:
>>> Hi Eike,
>> with XML persistence, then yes, they can.
> When Ecore model is created inside a CDO environment, the EObjects are created as CDOObjects. Where is this
>> EObject is a concept of the Ecore meta meta model.
>> All starts here:
Re: etypes.ecore [message #1248672 is a reply to message #1247829] |
Mon, 17 February 2014 09:28  |
Ecore is handled by CDO as a "legacy model": because Ecore is
generated without native CDO support (its implementation classes do not
implement the CDOObject interface, neither by extending CDOObjectImpl
nor by other means), CDO has to "adapt" the objects in an Ecore model
instance. This is accomplished by means of an Adapter (in the EMF
sense) attached to each object. It is this adapter that implements the
CDOObject protocol, providing the bridge that integrates Ecore into the
CDO framework.
You will see this if you look into the eAdapters() list of any element
of an Ecore model loaded from a CDO repository. You will find a
CDOLegacyAdapter attached to each.
All "model" resources in a CDO repository necessarily are CDOResources:
that's just what the resource factory associated with a CDO view's
resource-set will create, and what is required for persistence in CDO.
Whether it contains CDO-native (generated for CDO) models or "legacy
models" such as Ecore is immaterial.
HTH,
Christian
On 2014-02-16 17:16:23 +0000, UmaShankar Subramani said:
>>> Hi Eike,
>> modifies the >GenModels to generate your model classes as subclasses of
>> models, when >generated for CDO, can still be used with XML
> I call Normally)
> created as CDOObjects. Where is this happenning?, How the CDO classes
>> in some sense >CDO extends Ecore because EObject is a concept of the
>> All starts here:
Current Time: Sat Jul 26 04:36:50 EDT 2025
Powered by FUDForum. Page generated in 0.05038 seconds
