Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Are CDO Transactions transparent?
Are CDO Transactions transparent? [message #124355] Fri, 30 May 2008 23:27 Go to next message
According to Eike Stepper (see link to post below), transactions are
transparent and we don't need to worry about them when editing our EMF
model. If that's the case, how do we control transactions when we need to,
for instance, say I change several fields in a model, but don't want to
have them sent over the wire until I hit the "save" button?
http://dev.eclipse.org/newslists/news.eclipse.tools.emf/msg1 1555.html
Thank you in advance!
Re: Are CDO Transactions transparent? [message #124394 is a reply to message #124355] Sat, 31 May 2008 13:09 Go to previous messageGo to next message
Originally posted by: stepper.sympedia.de
--------------000707030305000104080206
AJ,
A CDOTransaction is transparently associated with a resource set and you
can work with the contained resources and objects as usual without
bothering about the technical internals of the transaction. That said,
usually, depending on your application design, you have also access to
the transaction itself and cann call methods like commit(), rollback()
and setSavePoint() (coming soon). A common pattern is the following:
| CDOSessionConfiguration configuration = CDOUtil.createSessionConfiguration();
configuration.setConnector(connector);
configuration.setRepositoryName("my-repo");
CDOSession session = configuration.openSession();
session.getPackageRegistry().putEPackage(Model1Package.eINST ANCE);
CDOTransaction transaction = session.openTransaction();
CDOResource resource = transaction.getOrCreateResource("/path/to/my/resource");
*EObject object = Model1Factory.eINSTANCE.createCompany();
resource.getContents().add(object);
transaction.commit();
session.close();|
Note that in the bold code region you can work with the resource, its
resource set and the contained objects as usual. But you can, if you
want also use the special CDO API in addition at any point in time.
Btw. when you click Save in the shipped CDO editor under the covers a
commit of the transaction that is associated with the resources set of
the editor is triggered.
Cheers
/Eike
AJ schrieb:
> to, for instance, say I change several fields in a model, but don't
> want to have them sent over the wire until I hit the "save" button?
<html>
<head>
http-equiv="Content-Type">
</head>
AJ,<br>
<br>
you can work with the contained resources and objects as usual without
and setSavePoint() (coming soon). A common pattern is the following:<br>
<br>
<title></title>
<style type="text/css">
<!--code { font-family: Courier New, Courier; font-size: 10pt; margin: 0px; }-->
</style>
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
<!-- = Java Sourcecode to HTML automatically converted code = --><!-- = Java2Html Converter 5.0 [2006-02-26] by Markus Gebhard markus@jave.de = -->
<!-- = Further information: http://www.java2html.de = -->
<div class="java" align="left">
<table bgcolor="#ffffff" border="0" cellpadding="3" cellspacing="0">
<tbody>
<tr>
<!-- start source code --> <td align="left" nowrap="nowrap"
valign="top"> <code><font color="#ffffff">
Re: Are CDO Transactions transparent? [message #124424 is a reply to message #124394] Sat, 31 May 2008 13:59 Go to previous message
--------------060506000509030309010107
AJ,
It might also be of interest that you can open several transactions on a
single session. Then you get several resource sets (one per transaction)
and you can work with them concurrently. The modeled state of the
objects is automatically shared among all transactions of the session
until one transaction modifies that state. All that happens
transparently under the covers.
Cheers
/Eike
Eike Stepper schrieb:
> AJ,
> session.close();|
> Cheers
> /Eike
> AJ schrieb:
>> Hi,
>> EMF model. If that's the case, how do we control transactions when we
>> need to, for instance, say I change several fields in a model, but
>> don't want to have them sent over the wire until I hit the "save"
>> button?
<html>
<head>
</head>
AJ,<br>
<br>
a single session. Then you get several resource sets (one per
transaction) and you can work with them concurrently. The modeled state
of the objects is automatically shared among all transactions of the
session until one transaction modifies that state. All that happens
transparently under the covers.<br>
<br>
Cheers<br>
/Eike<br>
<br>
<br>
<br>
<blockquote cite="mid:g1s0ou$a7o$1@build.eclipse.org" type="cite">
AJ,<br>
<br>
<br>
<title></title>
</style>
<meta http-equiv="Content-Type" content="text/html; ">
<!-- = Java Sourcecode to HTML automatically converted code = --><!-- = Java2Html Converter 5.0 [2006-02-26] by Markus Gebhard markus@jave.de = --><!-- = Further information: http://www.java2html.de = -->
<tbody>
<tr>
Re: Are CDO Transactions transparent? [message #619120 is a reply to message #124355] Sat, 31 May 2008 13:09 Go to previous message
AJ,
session.close();|
Cheers
/Eike
AJ schrieb:
<html>
<head>
</head>
AJ,<br>
<br>
<br>
<title></title>
</style>
<tbody>
<tr>
Re: Are CDO Transactions transparent? [message #619122 is a reply to message #124394] Sat, 31 May 2008 13:59 Go to previous message
AJ,
Cheers
/Eike
> AJ,
> session.close();|
> Cheers
> /Eike
> AJ schrieb:
>> Hi,
>> button?
<html>
<head>
</head>
AJ,<br>
<br>
<br>
Cheers<br>
/Eike<br>
<br>
<br>
<br>
AJ,<br>
<br>
<br>
<title></title>
</style>
<tbody>
<tr>
Previous Topic:[CDO] Does CDO fit in our scenario?
Next Topic:EMF Compare - Comparing XSD (XML schema)
Current Time: Wed Jul 23 00:45:43 EDT 2025
Powered by FUDForum. Page generated in 0.24650 seconds
