Re: to save state of application in e4 using save state in application work bench advisor [message #1243904 is a reply to message #1243736] |
Tue, 11 February 2014 11:10  |
Basically i want to save state of an application.to save state of an editor or view
I use save state method. Which is overridden method of iviewpart.when the workbench shutsdown
This save state method of opened views are called with a object of imemento.
Now in this i memento i create user defined keys.
When the workbench is created again this memento i read it back and i save the view back to previous state
Now this i do for a view.
In the same way i wantto store some application data in imemento.
In application work bench advisor i have overriden save state and restore state but when i
Add debug points to these 2 functions the control does not come there
Iam using eclipse 4 and mine is rcp application.is it that e4 does not have application work bench advisor class?
But methods like prestartup preshut down of application work bench advisor are getting executed
What has to be done so that save and restore method gets called?
Is there any other way in eclipse 4 to store application level data?
FUDForum. Page generated in 0.09454 seconds
