Integrating plugin bundles in normal Java [message #124324] |
Mon, 12 January 2009 18:03  |
Hi experts,
I have been trying to start an osgi application with another POJO main
method for integration.
I used the following in the main method of a public static main method:
String[] launcherArgs = {
"-configuration",
"C:\\pathTto\\configuration",
"-install",
"C:\\pathToIntall",
" -DJavaAgentLogConfigFile=C:\\pathToLogConfig\\log4j-commandl ine.xml ",
"-application",
"org.my.Application",
org.eclipse.core.launcher.Main.main(launcherArgs);
The above class can be found in startup.jar.
However, now my problem is how to return an result object from my App A.
org.eclipse.core.launcher.Main.main(launcherArgs) and
org.eclipse.equinox.launcher.Main.main(launcherArgs) does not have return
type. If my app A which implements
org.eclipse.core.runtime.IPlatformRunnable does return an result object in
its public Object run(args) method, how do I retrieve it?
I tried cutting over to use EclipseStarter:
BundleContext context = EclipseStarter.startup(launcherArgs, null);
Object appResult = EclipseStarter.run(null);
However, I think I am not able to use the same configuration parameters as
before:
!ENTRY org.eclipse.osgi 4 0 2009-01-09 16:02:58.719
!MESSAGE Bundle org.eclipse.core.runtime@start not found.
!ENTRY org.eclipse.update.configurator 2009-01-09 16:02:58.859
!MESSAGE C:\pathTo\plugins is not a valid plugins directory.
Any idea?
Tom
Re: Integrating plugin bundles in normal Java [message #124362 is a reply to message #124324] |
Tue, 13 January 2009 09:45  |
Tom,
I'd go the EclipseStarter way personally. You might take a look at the
FrameworkLauncher in org.eclipse.equinox.servletbridge for inspiration.
"Tom Hsu" <tomhsu@gmail.com> wrote in message
news:fc51bc65570f23077826b0ec425b2242$1@www.eclipse.org...
> Hi experts,
> public static void main(String[] args) {
> "-configuration",
> "-install",
> "C:\\pathToIntall",
> "-application",
> before:
> Any idea?
> Regards,
> Tom
FUDForum. Page generated in 0.03217 seconds
