Workspace does not open, but import it and then it's OK [message #1242476] |
Sun, 09 February 2014 11:36  |
I'm using Eclipse Kepler DSL version (with Xtext and Xtend built-in).
I am using SVN to check my Java/DSL code out to my Windows 7 laptop, and to check-in any changes.
Recently I decided to NOT put .metadata, ./bin, and ./src-gen under revision control. So, the workspaces in question do not have those files and folders in sync with the source code.
If I open Eclipse and then select the workspace in question, Eclipse opens, does not complain about anything, yet nothing appears in the Project Explorer.
So then, I checked out the branch from SVN to a new folder. Tried opening this workspace from Eclipse. Same as before. Then, if I "Import Existing Projects into Workspace" from the original location, everything works.
I'd rather be able to access my workspace in its original location, for obvious reasons.
FUDForum. Page generated in 0.11377 seconds
