Home » Language IDEs » Java Development Tools (JDT) » Getting Java 8 support in Eclipse Luna
Getting Java 8 support in Eclipse Luna [message #1242162] Sat, 08 February 2014 23:41 Go to next message
Hello
Has anyone got Eclipse Luna (M5) Java 8 support to successfully work?
There seem to be two pages which describe how to get it to work:
https://wiki.eclipse.org/JDT_Core/Java8
and
https://wiki.eclipse.org/JDT/Eclipse_Java_8_Support_(BETA)
None of them mention Luna but refer to Kepler, so i might be going wrong straight away with that! Anyhow, I have installed the java 8 support packages from the dist.springsource.com .../e43 repository (there's no 4.4 ref!), and I have a jdk8 installed (which i named as per the first page). But i do not see a compliance level 1.8 in my eclipse. Attempts to set it to 1.8 manually in my project override - org.eclipse.jdt.core.prefs seem to be ignored.
Can anyone help?
thanks!
Re: Getting Java 8 support in Eclipse Luna [message #1242889 is a reply to message #1242162] Mon, 10 February 2014 03:08 Go to previous messageGo to next message
Luna m5 works like a charme for me! I simply used the springsource
update site and installed all available feature patches.
Tom
On 10.02.14 01:15, Steven Parry wrote:
> Hello
> and
> Can anyone help?
> thanks!
Re: Getting Java 8 support in Eclipse Luna [message #1243018 is a reply to message #1242889] Mon, 10 February 2014 06:52 Go to previous messageGo to next message
Thanks for the response. I tried 4.3 too so I know it isn't that.
Did you have to do anything special? Eg jre naming?
One thing I noticed - there are three packages for the java 8 support. Only two install for me - the jdt patch and the RCP support. The other one - plugin dev env patch does not install with 'not applicable to the current configuration'
Steve
Re: Getting Java 8 support in Eclipse Luna [message #1257412 is a reply to message #1243018] Wed, 26 February 2014 06:47 Go to previous message
Please discontinue the usage of the Spring Source Site and use the following site for update:
Official Update Site http://build.eclipse.org/eclipse/builds/4P/siteDir/updates/4.3-P-builds
Previous Topic:Problem with compiling and running a small program
Next Topic:How to Programatically run '.launch' file ?
Current Time: Mon May 12 17:45:59 EDT 2025
Powered by FUDForum. Page generated in 0.02898 seconds
