Home » Modeling » TMF (Xtext) » OutputConfigurationProvider with empty output-directory
OutputConfigurationProvider with empty output-directory [message #996980] Thu, 03 January 2013 05:35 Go to next message
In my project I want the generator to write file directly to the
project-folder instead of some subfolder.
I tried the following settings: "", "." but they all lead to an
exception, the only possible solution for now is that I define "src" and
then when creating the path in the generator i prefix it with "../".
The exception thrown is:
> !STACK 0
> java.lang.IllegalArgumentException: Path must include project and resource name: /my.fx.test
> at org.eclipse.core.runtime.Assert.isLegal(Assert.java:63)
> at org.eclipse.core.internal.resources.Workspace.newResource(Workspace.java:2163)
> at org.eclipse.core.internal.resources.Container.getFolder(Container.java:215)
> at org.eclipse.xtext.builder.BuilderParticipant.refreshOutputFolders(BuilderParticipant.java:231)
> at org.eclipse.xtext.builder.BuilderParticipant.build(BuilderParticipant.java:125)
> at org.eclipse.xtext.builder.impl.RegistryBuilderParticipant.build(RegistryBuilderParticipant.java:60)
> at org.eclipse.xtext.builder.impl.XtextBuilder.doBuild(XtextBuilder.java:161)
> at org.eclipse.xtext.builder.impl.XtextBuilder.incrementalBuild(XtextBuilder.java:141)
> at org.eclipse.xtext.builder.impl.XtextBuilder.build(XtextBuilder.java:91)
> at org.eclipse.core.internal.events.BuildManager$2.run(BuildManager.java:728)
> at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
> at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:199)
> at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:239)
> at org.eclipse.core.internal.events.BuildManager$1.run(BuildManager.java:292)
> at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:295)
> at org.eclipse.core.internal.events.BuildManager.basicBuildLoop(BuildManager.java:351)
> at org.eclipse.core.internal.events.BuildManager.build(BuildManager.java:374)
> at org.eclipse.core.internal.events.AutoBuildJob.doBuild(AutoBuildJob.java:143)
> at org.eclipse.core.internal.events.AutoBuildJob.run(AutoBuildJob.java:241)
> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:53)
The drawback with this is that if the user does not have src-directory
it gets created.
Is there a possibility to make the xtext generate relative to the
root-folder?
Tom
Re: OutputConfigurationProvider with empty output-directory [message #998038 is a reply to message #996980] Wed, 09 January 2013 03:42 Go to previous messageGo to next message
I have exactly the same problem (I'd like to generate a
plugin.xml_my_gen) in the root folder...
the trick of "../" does not work for me either could you please share to
code Tom?
thanks
cheers
Lorenzo
On 01/03/2013 11:35 AM, Tom Schindl wrote:
>> !STACK 0
> it gets created.
> root-folder?
> Tom
ICQ# lbetto, 16080134 (GNU/Linux User # 158233)
HOME: http://www.lorenzobettini.it MUSIC: http://www.purplesucker.com
http://www.myspace.com/supertrouperabba
BLOGS: http://tronprog.blogspot.com http://longlivemusic.blogspot.com
http://www.gnu.org/software/src-highlite
http://www.gnu.org/software/gengetopt
http://www.gnu.org/software/gengen http://doublecpp.sourceforge.net
Re: OutputConfigurationProvider with empty output-directory [message #998251 is a reply to message #998038] Wed, 09 January 2013 11:46 Go to previous messageGo to next message
Hi Lorenzo,
All my code is opensource.
The generator:
https://github.com/tomsontom/e-fx-clipse/blob/master/at.bestsolution.efxclipse.tooling.fxgraph/src/at/bestsolution/efxclipse/tooling/fxgraph/generator/FXGraphGenerator.xtend
The outputconfig provider:
https://github.com/tomsontom/e-fx-clipse/blob/master/at.bestsolution.efxclipse.tooling.fxgraph/src/at/bestsolution/efxclipse/tooling/fxgraph/compiler/FXGraphOutputConfigurationProvider.java
Tom
Am 09.01.13 09:42, schrieb Lorenzo Bettini:
> Hi
> code Tom?
> thanks
> cheers
> Lorenzo
>> Hi,
>>> !STACK 0
>> it gets created.
>> root-folder?
>> Tom
Re: OutputConfigurationProvider with empty output-directory [message #998541 is a reply to message #998251] Thu, 10 January 2013 02:45 Go to previous messageGo to next message
Hi Tom,
would you mind filing a ticket with a patch attached? That would be great.
Sebastian
Looking for professional support for Xtext, Xtend or Eclipse Modeling?
Am 09.01.13 17:46, schrieb Tom Schindl:
> Hi Lorenzo,
> The generator:
> Tom
>> Hi
>> code Tom?
>> thanks
>> cheers
>> Lorenzo
>>> Hi,
>>>> !STACK 0
>>> it gets created.
>>> root-folder?
>>> Tom
Re: OutputConfigurationProvider with empty output-directory [message #999228 is a reply to message #996980] Fri, 11 January 2013 10:49 Go to previous messageGo to next message
OK, now this hack works for me, but there's a drawback of this approach:
if I remove an element in my program which corresponds to a generated
resource, the previously generated file is not removed.
I have set
projectRootOutput.setOutputDirectory("src");
projectRootOutput.setOverrideExistingResources(true);
projectRootOutput.setCreateOutputDirectory(true);
projectRootOutput.setCanClearOutputDirectory(false);
projectRootOutput.setCleanUpDerivedResources(true);
projectRootOutput.setSetDerivedProperty(true);
but when the build participant executes these lines
Map<OutputConfiguration, Iterable<IMarker>> generatorMarkers =
newHashMap();
for (OutputConfiguration config : outputConfigurations.values()) {
if (config.isCleanUpDerivedResources()) {
final IFolder outputFolder =
builtProject.getFolder(config.getOutputDirectory());
final Iterable<IMarker> markers =
derivedResourceMarkers.findDerivedResourceMarkers(outputFolder,
generatorIdProvider.getGeneratorIdentifier());
generatorMarkers.put(config, markers);
it search for markers in the output directory (which is "src"), thus it
cannot find the generated resources in the project root...
probably a custom version of
DerivedResourceMarkers.findDerivedResourceMarkers could solve the
problem by using a modified IFolder... that would be a hack built upon
another hack ;)
has a feature request already been filed?
cheers
Lorenzo
Re: OutputConfigurationProvider with empty output-directory [message #1241989 is a reply to message #999228] Sat, 08 February 2014 16:47 Go to previous message
Note to future readers finding this by searching for the respective error: Issue https://bugs.eclipse.org/bugs/show_bug.cgi?id=386135 dealt with this problem. It appears fixed in e.g. v2.4.3, but not in e.g. old v2.3.1. Just recording this here - not asking for any reply or suggesting any action.
Previous Topic:Tutorial question: IQualifiedNameProvider needs explicit type
Next Topic:Evicting cache based on a particular element value being modified
Current Time: Sat Jul 26 23:43:04 EDT 2025
Powered by FUDForum. Page generated in 0.07487 seconds
