Home » Modeling » TMF (Xtext) » correct reference problem with import statement and unti-test(No reference between import-statement and calling other files. No reference bewtween files at unit-testing.)
correct reference problem with import statement and unti-test [message #1241881] Sat, 08 February 2014 12:52 Go to next message
I want to create a dsl with xtext. The new dsl should describe the sequence of tests. With an xml-generator i convert the new dsl to a xml file that a programm can read.
I have a problem with the import-statement and the references. I search two days at the internet, but found no solution for my problem.
Here is my project (simplified):
The Target:
please look into the file at-files.txt (i cannot load the code here)
Explanation:
run and call are key words. With run you can run a test and with call you can call a other test (full test (call AT01) or a test step (call AT01.method1)).
The problem:
When I have the folowing project structure:
/root/files1/AT02.atd
/root/files1/AT01.atd
/root/files2/AT01.atd
The reference in the file AT02.atd are not always correct. Sometimes there are the reference to /root/files2/AT01.atd or sometimes to /root/files1/AT01.atd. There are no check if the import file existes or a reference between the import-statement at the top of the file and the call statement.
I want the exact reference to the file AT01.atd with the import-statment. A nive-to-have is an autocomplete for the import-statement. But I do not know how to Sad .
The implementation:
The Grammar:
please look into the file grammar.xtext (i cannot load the code here)
The workflow (snippet):
I have these lines at the workflow for the import problem
// scoping and exporting API
fragment = scoping.ImportNamespacesScopingFragment auto-inject {}
fragment = exporting.QualifiedNamesFragment auto-inject {}
fragment = builder.BuilderIntegrationFragment auto-inject {}
Unit-testing with import-references:
My second problem is the import-references at the unit-testing.
introduction: I want to test the xml-generator. So I create in the package *.tests a file GeneratorTest.xtend. In a other package *.files I have the files AT01.atd and AT02.atd (from above) and the correct xml-files (self-written) to these atd-files.
My Attempt: I read in the GeneratorTest.xtend the files AT01.atd and AT02.atd. Then I call the generator and I have in the package *.files.gen the new xml-files). Then I want to compare the self-written xml-files and the generated xml-files.
The Problem: There are no references between the files.
please look into the file unitTest.xtend (i cannot load the code here)
The Problem: the res is null.
How can I test correct my xml-generator (compare self written xml file with generated xml file).
Re: correct reference problem with import statement and unti-test [message #1242858 is a reply to message #1241881] Mon, 10 February 2014 02:22 Go to previous messageGo to next message
you are the guy who has to load all relevant files into the resource set yourself, not only one.
Re: correct reference problem with import statement and unti-test [message #1242950 is a reply to message #1242858] Mon, 10 February 2014 05:00 Go to previous messageGo to next message
Christian I do not understand. What exactly do you mean? Which resource set do you mean?
Re: correct reference problem with import statement and unti-test [message #1242959 is a reply to message #1242950] Mon, 10 February 2014 05:14 Go to previous messageGo to next message
the one in the test????
Re: correct reference problem with import statement and unti-test [message #1242985 is a reply to message #1242959] Mon, 10 February 2014 05:57 Go to previous messageGo to next message
I still do not understand Sad
Do you mean this line : "val resource = resourceSet.getResource(fileURI, true);" ?
For every file I call the method doGenerate(...) and then for every file I make a "new ResourceSetImpl();". So I do not load all files into the same resource set.
With the ResourceSetImpl I want only to get the Resource of the file.
But why it is wrong to load more files into a resouce set? A resource set is a "collection of resources" or am I wrong?
How could I fix it in your opinion?
Re: correct reference problem with import statement and unti-test [message #1242988 is a reply to message #1242985] Mon, 10 February 2014 06:03 Go to previous messageGo to next message
yes
you have to do
val resource1 = resourceSet.getResource(fileURI1, true);"
val resource2 = resourceSet.getResource(fileURI2, true);"
val resource3 = resourceSet.getResource(fileURI3, true);"
Re: correct reference problem with import statement and unti-test [message #1242989 is a reply to message #1242988] Mon, 10 February 2014 06:03 Go to previous messageGo to next message
and it is not wrong. you have todo it but you dont do it!
if you would do it you would not have unresolved reference problems
Re: correct reference problem with import statement and unti-test [message #1243148 is a reply to message #1242989] Mon, 10 February 2014 10:33 Go to previous messageGo to next message
Ah clear. Great, thank you. It works. Sorry I was confused.
Do you know the solution of my first problem too (Not in the unit test)? With the correct import-statement so i can call the right file (when i have two with the same name in a folder tree). Thus i have no reference between import-statement (import files1.AT01) and call-statement (call AT01)?
Re: correct reference problem with import statement and unti-test [message #1243157 is a reply to message #1243148] Mon, 10 February 2014 10:46 Go to previous messageGo to next message
Did you try to switch to import uri based scoping?
Re: correct reference problem with import statement and unti-test [message #1243597 is a reply to message #1243157] Tue, 11 February 2014 02:22 Go to previous messageGo to next message
Did you mean write this line in the workflow: "fragment = scoping.ImportURIScopingFragment auto-inject {}" ? This do not work. And I try in the grammar "'import' importURI=STRING;" but this do not work, too.
Re: correct reference problem with import statement and unti-test [message #1243635 is a reply to message #1243597] Tue, 11 February 2014 03:23 Go to previous messageGo to next message
Make sure you remove xbase and types generator and importednamespace
fragments
Need training, onsite consulting or any other kind of help for Xtext?
Go visit http://xtext.itemis.com or send a mail to xtext at itemis dot de
Re: correct reference problem with import statement and unti-test [message #1243653 is a reply to message #1243635] Tue, 11 February 2014 04:02 Go to previous messageGo to next message
Here are my actual workflow. When I remove the line "fragment = types.TypesGeneratorFragment auto-inject {}" there are no references and errors at my dsl.
Re: correct reference problem with import statement and unti-test [message #1243711 is a reply to message #1243653] Tue, 11 February 2014 05:42 Go to previous messageGo to next message
do you use xbase in your dsl?
Re: correct reference problem with import statement and unti-test [message #1243747 is a reply to message #1243711] Tue, 11 February 2014 06:39 Go to previous messageGo to next message
No I use only the super grammar org.eclipse.xtext.common.Terminals.
Re: correct reference problem with import statement and unti-test [message #1243754 is a reply to message #1243747] Tue, 11 February 2014 06:46 Go to previous messageGo to next message
Then I do not understand that. What is the symptoms exactly you get?
Re: correct reference problem with import statement and unti-test [message #1243770 is a reply to message #1243754] Tue, 11 February 2014 07:18 Go to previous messageGo to next message
In my dsl I have this folder structure:
ProjectFolder/
|-- src/
|-- packA.packB/
|-- AT01.atd
|-- AT02.atd
|-- packA.packB/
|-- AT02.atd
|-- src-gen/
AT01.atd look like this:
import packA.packB.AT02
test AT01 {
call AT02 //(here is a link to packA.packC.AT02 and not to packA.packB.AT02!)
So when I click on AT02 and press F3 I go to packA.packC.AT02 and that it not what I expect/want (my grammar is at the first post). So I have no reference between my import-statement and my call-statement (I can also let off statement). And I do not find any solution on the internet (I try) that works.
Re: correct reference problem with import statement and unti-test [message #1243775 is a reply to message #1243770] Tue, 11 February 2014 07:26 Go to previous messageGo to next message
i get more and more confused.
do you want to import packages or do you want to import uris
if packages: are they explicitely declared or derived from the folder.
if they are derived from the folder did you customize the nameprovider for your root object
to give its package name as name
Re: correct reference problem with import statement and unti-test [message #1243842 is a reply to message #1243775] Tue, 11 February 2014 09:25 Go to previous messageGo to next message
Sorry. It should actually ony folders (but with packages it should work too, but it do not):
ProjectFolder/src/folderA/folderB/AT01.atd
ProjectFolder/src/folderA/folderB/AT02.atd
ProjectFolder/src/folderA/folderC/AT02.atd
The import should work like java. With the statement "import folderA.folderB.AT02" I want to call the file AT02.atd in the folder ProjectFolder/src/folderA/folderB/
I try to add a package declaration to the grammar but without success.
Re: correct reference problem with import statement and unti-test [message #1243855 is a reply to message #1243842] Tue, 11 February 2014 09:43 Go to previous messageGo to next message
i have no access to your grammar.
so do you have packagesa there or not?
ifyou have only folders you have to adaot the nameprovider and calculent the package from the roots eResource URI
Re: correct reference problem with import statement and unti-test [message #1244562 is a reply to message #1243770] Wed, 12 February 2014 09:22 Go to previous message
It sounds like the qualified name provider use the simple name, and
doesn't include the package.
You need to either have a special implementation of
IQualifiedNameProvider (and bind it via your guice module) or you change
your grammar such that the
test element are contained in something with a name, which denotes the
package.
i.e.
File :
'package' name=QualifiedName
tests += Test*
Test :
'test' name=ID ...
hope that helps,
Sven
Am 11/02/14 13:18, schrieb Marcel Lgs:
> ProjectFolder/
> |-- src/
> |-- packA.packB/
> |-- AT01.atd
> |-- AT02.atd
> |-- packA.packB/
> |-- AT02.atd
> |-- src-gen/
> test AT01 {
> packA.packB.AT02!)
> (I try) that works.
Need professional support for Xtext or other Eclipse Modeling technologies?
Go to: http://xtext.itemis.com
Twitter : @svenefftinge
Blog : http://blog.efftinge.de
Previous Topic:Generated ecore models refer to Xbase using relative paths
Next Topic:[Solved] DocumentTokenSource Injection
Current Time: Sun Jul 20 23:25:20 EDT 2025
Powered by FUDForum. Page generated in 0.06850 seconds
