Home » Eclipse Projects » Equinox » URGENT: configure Jetty to load index.html when http://localhost is given
URGENT: configure Jetty to load index.html when http://localhost is given [message #124182] Sat, 10 January 2009 09:57 Go to next message
How to configure jetty to load index.html by default when hitting
http://localhost
- Walter.
Re: URGENT: configure Jetty to load index.html when http://localhost is given [message #124375 is a reply to message #124182] Tue, 13 January 2009 09:48 Go to previous messageGo to next message
The OSGI Http Service does not directly support "welcome files". If you want
to support this you can do this yourself by taking and customizing the
ResourceServlet. See org.eclipse.equinox.http.helpers in the Equinox
Incubator (Currently in /cvsroot/eclipse/equinox-incubator but will
eventually be moving to the RT incubator).
-Simon
"Walter Prabhakar" <kwchess@gmail.com> wrote in message
news:gkact4$l5l$1@build.eclipse.org...
> http://localhost
> Thanks
> - Walter.
Re: URGENT: configure Jetty to load index.html when http://localhost is given [message #124471 is a reply to message #124375] Wed, 14 January 2009 10:08 Go to previous messageGo to next message
Thanks Simon. It works.
"Simon Kaegi" <simon_kaegi@ca.ibm.com> wrote in message
news:gki9k0$jkk$1@build.eclipse.org...
> want to support this you can do this yourself by taking and customizing
> the ResourceServlet. See org.eclipse.equinox.http.helpers in the Equinox
> -Simon
>> http://localhost
>> Thanks
>> - Walter.
Re: URGENT: configure Jetty to load index.html when http://localhost is given [message #124484 is a reply to message #124471] Wed, 14 January 2009 11:21 Go to previous messageGo to next message
Walter,
If you have a decent implementation of WelcomeServlet would you consider
sharing it.
It would be good to iterate on a solution here and I'd like to help to get
one canonical solution that's bug-free for this problem and then add it back
into org.eclipse.equinox.http.helpers.
-Simon
news:gkkv33$1vo$1@build.eclipse.org...
>> -Simon
>>> http://localhost
>>> Thanks
>>> - Walter.
Re: URGENT: configure Jetty to load index.html when http://localhost is given [message #124595 is a reply to message #124484] Thu, 15 January 2009 08:54 Go to previous message
Simon, I had just copied ResourceServlet to my project and added the 2
lines as shown below between <Walter> .
Basically the default page could be retrieved from init params of servlet
definition from plugin.xml and can be used instead of "/index.html".
I am not sure if this is the right solution. However, it worked for my web
page http://www.propertymapz.com
public void service(ServletRequest req, ServletResponse resp) throws
ServletException, IOException {
HttpServletRequest httpRequest = (HttpServletRequest) req;
HttpServletResponse httpResponse = (HttpServletResponse) resp;
String method = httpRequest.getMethod();
if (method.equals("GET") || method.equals("POST") ||
method.equals("HEAD")) { //$NON-NLS-1$//$NON-NLS-2$ //$NON-NLS-3$
String resourcePath = internalName + httpRequest.getPathInfo();
// <Walter>
if ( "/".equals ( resourcePath ) )
resourcePath = "/index.html" ;
// <Walter>
if (!writeResource(httpRequest, httpResponse, resourcePath)) {
httpResponse.setStatus(HttpServletResponse.SC_NOT_FOUND);
} else
httpResponse.setStatus(HttpServletResponse.SC_METHOD_NOT_ALL OWED);
news:gkl3de$a50$1@build.eclipse.org...
> Walter,
> sharing it.
> back into org.eclipse.equinox.http.helpers.
> -Simon
>>> -Simon
>>>> http://localhost
>>>> Thanks
>>>> - Walter.
Previous Topic:p2 does not display installed dependency plugins.
Next Topic:Native Libraries for Mac: dylib instead of jnilib
Current Time: Sat Jul 19 00:07:44 EDT 2025
Powered by FUDForum. Page generated in 0.10029 seconds
