Home » Modeling » TMF (Xtext) » Strange left recursive rules(Cannot find recursive problems)
Strange left recursive rules [message #1241708] Sat, 08 February 2014 06:20 Go to next message
I faced a recursive rule problem in Xtext. The simplify version is as follow:
Atomic:
    Map |
    FunctionCall |
    value=ID;
Map:
    'map' '{'
        (entries+=MapEntry)+
MapEntry:
    '(' key=Atomic ')' '=>' value=Atomic;
FunctionCall:
    name=ID '(' arg=Atomic ')';
And Xtext give me error message:
[fatal] rule ruleAtomic has non-LL(*) decision due to recursive rule invocations reachable from alts 2,3.  Resolve by left-factoring or using syntactic predicates or using backtrack=true option.
But i cannot find left recursive problems. Is there some implicit rules in Xtext about the left recursive?
Thanks.
Re: Strange left recursive rules [message #1241713 is a reply to message #1241708] Sat, 08 February 2014 06:30 Go to previous messageGo to next message
The other case is as follow:
Statement:
atomic+=Atomic*;
Atomic:
  '(' Atomic ')' |
  FunctionCall |
  value=ID;
FunctionCall:
I can understand that this one has ambiguity, but why does Xtext also warning about:
Re: Strange left recursive rules [message #1242092 is a reply to message #1241713] Sat, 08 February 2014 20:52 Go to previous messageGo to next message
> Statement:
> atomic+=Atomic*;
> Atomic:
> '(' Atomic ')' |
> FunctionCall |
> value=ID;
> FunctionCall:
> warning about:
To get help with problems like these, you need to post your entire grammar.
- henrik
Re: Strange left recursive rules [message #1242712 is a reply to message #1242092] Sun, 09 February 2014 20:55 Go to previous messageGo to next message
Henrik Lindberg wrote on Sat, 08 February 2014 20:52
- henrik
Thanks for your reply.
These two cases are both complete grammar extracted from my whole grammar.
Adding any header like:
grammar my.mavenized.HeroLanguage with org.eclipse.xtext.common.Terminals
generate heroLanguage "http://www.mavenized.my/HeroLanguage"
They can be checked by Xtext tools.
Re: Strange left recursive rules [message #1242752 is a reply to message #1241708] Sun, 09 February 2014 22:33 Go to previous messageGo to next message
> follow:
> follow:
Atomic
: Map
| FunctionCall
| value=ID
Map
: 'map' '{' (entries+=MapEntry)+ '}'
MapEntry
: '(' key=Atomic ')' '=>' value=Atomic
FunctionCall
: name=ID '(' arg=Atomic ')'
I re-formatted the grammar to make it easier to read.
The problems here are:
* When looking at an Atomic and the next token is ID, it does not know
if this is a Atomic with value = ID, or a FunctionCall since the
function call also starts with an ID.
* Second problem is that LL(*) parsing does not have precedence on
operators and it does not know if to "shift or reduce" (in other parsing
technologies). This is something that must be manually resolved by the
grammar author when using LL. This is called "left factoring". You get
this in the FunctionCall rule which boils down to ID '(' ID
i.e. something like this does not work in a LL parser
Expression
: Expression '+' Expression
| Expression '-' Expression
Suggest you look at one of the Expression based examples for Xtext.
(There is a formula to follow - it is not as hard as it first looks once
you get the hang of it).
I hope that helps
- henrik
Re: Strange left recursive rules [message #1242790 is a reply to message #1242752] Sun, 09 February 2014 23:59 Go to previous messageGo to next message
Henrik Lindberg wrote on Sun, 09 February 2014 22:33
Expression
Thanks for you reply.
1. For the first problem, i think that Xtext is working in a greedy match way that it should not be problem. I write a test as follow:
Atomic
 FunctionCall
| TheOtherFunctionCall
FunctionCall
name=ID '[' arg=Atomic ']'
And it works well. So i think it may not be the core reason?
2. For the second problem, i know about using current to solve that Expression problem. But i still think maybe it is not the cause of problem? Because for the posted problematic grammar, if it enter the FunctionCall rule, it should know how to parse it.
See an example as follow:
getName(xi)
This is a rule of ID '(' ID ')' and only FunctionCall rule can be applied on it and not other Atomic rule can be used in my thought.
In the posted grammar, if i remove Map from Atomic rule, everything is OK. So i think the problem is happened in Map rule and FunctionCall, but i cannot figure out in which case will it be ambiguous.
Re: Strange left recursive rules [message #1243177 is a reply to message #1242790] Mon, 10 February 2014 11:24 Go to previous messageGo to next message
>> parsing technologies). This is something that must be manually
>> resolved by the grammar author when using LL. This is called "left
>> factoring". You get this in the FunctionCall rule which boils down to
>> ID '(' ID
>> Expression
> Atomic
> FunctionCall
> FunctionCall
> getName(xi)
As I said, you have to go and read up on how it actually works. I read a
great explanation in an ANTLr book ("The Definitive ANTLR reference")
how LL* parser works. It is not immediately intuitive when having worked
with other parser technologies.
Also look at other Xtext based grammars and how various programming
language constructs were implemented (calls, maps, etc).
- henrik
Re: Strange left recursive rules [message #1243456 is a reply to message #1243177] Mon, 10 February 2014 21:10 Go to previous messageGo to next message
Henrik Lindberg wrote on Mon, 10 February 2014 11:24
- henrik
Thanks. I'll read the book to see how it actually works.
Re: Strange left recursive rules [message #1243654 is a reply to message #1243456] Tue, 11 February 2014 04:04 Go to previous messageGo to next message
>> a great explanation in an ANTLr book ("The Definitive ANTLR
>> reference") how LL* parser works. It is not immediately intuitive when
>> having worked with other parser technologies.
>> - henrik
Hi Xi
there's also a chapter in my Xtext book about left-factoring using an
Expression language:
http://www.packtpub.com/implementing-domain-specific-languages-with-xtext-and-xtend/book
hope this helps
Lorenzo
HOME: http://www.lorenzobettini.it
Xtext Book:
Re: Strange left recursive rules [message #1256266 is a reply to message #1243654] Tue, 25 February 2014 03:56 Go to previous message
Hi Lorenzo,
I read your book and it helps a lot.
Thanks for your great work!
Previous Topic:Cross References in a dynamic language
Next Topic:Editor related issues in xtext
Current Time: Wed Jul 23 11:58:21 EDT 2025
Powered by FUDForum. Page generated in 0.06555 seconds
