Home » Eclipse Projects » Remote Application Platform (RAP) » Session timeout
Session timeout [message #124056] Mon, 09 March 2009 12:43 Go to next message
I want my application works without any session timeouts. So I supposed
that if I create a service handler and implement some code in javascript,
that will request the service handler via ajax, the session will never be
terminated. But It seems this is not working.
I can suppose that I have to add some extra-code to my service function in
my service handler. Is it right? And could you please provide this code if
it possible?
Thank you,
Igor
Re: Session timeout [message #124068 is a reply to message #124056] Mon, 09 March 2009 12:48 Go to previous messageGo to next message
you should be able to use setMaxInactivateInterval on the HTTPSession .A
negative value indicates that the session should never timeout (see
javadoc).
Cheers
Benny
Igor Pavlenko wrote:
> Hello,
> javascript, that will request the service handler via ajax, the session
> will never be terminated. But It seems this is not working.
> in my service handler. Is it right? And could you please provide this
> code if it possible?
> Thank you, Igor
Benjamin Muskalla | EclipseSource Karlsruhe
http://www.eclipsesource.com | http://twitter.com/eclipsesource
Re: Session timeout [message #124093 is a reply to message #124056] Mon, 09 March 2009 14:24 Go to previous messageGo to next message
> Hello,
This is the right approach, probably just a problem in your
implementation. I am almost certain that I read on this group that
someone managed to get this working.
> Thank you, Igor
Re: Session timeout [message #124143 is a reply to message #124093] Tue, 10 March 2009 05:02 Go to previous messageGo to next message
>> I am almost certain that I read on this group that someone managed to
get this working.
Search for an answer by Michael Haendel in the thread 'RAP and
(cluster-)failover'
Re: Session timeout [message #124183 is a reply to message #124056] Tue, 10 March 2009 07:46 Go to previous messageGo to next message
I think you just have to call
RWT.getRequest().getSession().setMaxInactiveInterval(-1); In your createUI
method of you EntryPoint:)
I have a simular problem:
I want to restart the application when the sessions timeout is reached.
I need some kind of session timeout event to call the workbench restart
method.
But is this method gona restart the rap session or just the workbench
inside the the rap-session. So I suppose I have to restart the complete
RAP-Session.
Do somebody know how I can do it?
The steps to solve it are:
1. Setting a Session time out (optional, I can keep the default time out)
2. Get a session time out event
3. Restart the rap-session
I dont know how to solve the steps 2 and 3.
best regards,
p-lex
Re: Session timeout [message #124196 is a reply to message #124183] Tue, 10 March 2009 07:52 Go to previous messageGo to next message
Originally posted by: benjamin.wolff.web.de
regarding step 2: you can attach a listener to the current session, try RWT.getSessionStore().addSessionStoreListener(...).
In this listener you must implement the method beforeDestroy(...). This method is called immediately before the session
is destroyed. Maybe this is what you are looking for?! I had some serious headache about the whole session thingy because
the session management is done by the underlying servlet container which makes it quite hard to cope with it sometimes...
greetings,
ben
> createUI method of you EntryPoint:)
> method.
> RAP-Session.
> best regards,
> p-lex
Re: Session timeout [message #124235 is a reply to message #124196] Tue, 10 March 2009 09:01 Go to previous messageGo to next message
thx for your help. The SessionStoreListener works fine. So now only the
step 3 is left to solve.
I see there is no IWorkbench#restart() method to restart the workbench.
There must be an other way to restart the session or maybe just to tell
the browser to reload the page or something like that.
I'm gonna search for a solution and post it, if not somebody else will do
it before.
p-lex
Re: Session timeout [message #124345 is a reply to message #124143] Thu, 12 March 2009 01:45 Go to previous messageGo to next message
There was a problem in my js-file (wrong url for ajax request).
Thank you,
Igor
Re: Session timeout [message #124358 is a reply to message #124235] Thu, 12 March 2009 01:48 Go to previous message
Thank you,
I fix the problem. The problem was in my javascript file with ajax request
functions.
Igor
Previous Topic:Trees and memory problems on IE 7
Next Topic:Communicate from applet to a custom widget
Current Time: Sat Jul 19 12:05:09 EDT 2025
Powered by FUDForum. Page generated in 0.05071 seconds
