Home » Modeling » TMF (Xtext) » Generating Java code for models with link errors
Generating Java code for models with link errors [message #1240934] Fri, 07 February 2014 03:43 Go to next message
As mentioned in a previous post, I've written a small DSL for writing
junit tests, as an example for a presentation and for use in a course
with test-based exercises. The typical way of using it is:
- preparing a solution (e.g. Person.java)
- writing the tests that link to the solution (Person.jextest)
- generating the test code (PersonTest.java) and provding it to the students
When the students start working (on their own version of the solution
(Person.java) there are naturally lots of error markers in the test
code, but the smart Eclipse parser is nevertheless able to generate and
execute it fairly quickly (with a minimal of working solution code). I'm
now looking at making the students use the DSL directly (not write, just
generate test code and executing the tests). This requires, that the
DSL's generator executes and generates meaningful code in the presences
of (lots of) linking errors (in JvmTypeReferences and XExpressions).
However, the generator isn't called until the model validates, which
won't happen until the student has written (stubs for) all the methods
required by the whole test. I would like to enable the generator as long
as the error markers are considered acceptable (in general local to in
JvmTypeReferences and XExpressions), and just make sure the generator is
fault tolerant.
How can this be done?
Hallvard
Re: Generating Java code for models with link errors [message #1240958 is a reply to message #1240934] Fri, 07 February 2014 04:12 Go to previous message
After search for occurrences of IGenerator, I think I've found the
solution: Bind a custom BuilderParticipant in the UIModule and override
the shouldGenerate method. Here the Resource's Diagnostics are
available, and I can check the kind of error (XtextLinkingDiagnostic).
I'm currently looking for a way to find the offending model element, to
see if the linking problem is in an acceptable place.
Hallvard
On 07.02.14 09:43, Hallvard Trætteberg wrote:
> students
> fault tolerant.
> Hallvard
Previous Topic:Cross references in DSLs of xtext
Next Topic:Using step filters when debugging DSL
Current Time: Sat Jul 26 23:23:58 EDT 2025
Powered by FUDForum. Page generated in 0.24549 seconds
