Home » Archived » BIRT » change query depending on locale [solved]
change query depending on locale [solved] [message #1223515] Mon, 23 December 2013 11:21 Go to next message
I'm trying to modify the SQL query for a Chart depending on the locale. What I get so far :
beforeFactory
var mylocale=reportContext.getLocale().toString().substr(1,2)
But I'm stuck on retrieving the parameter and inserting on the query. Something like this:
Select * from table where country=' + param["mylocale"] + '
Any help would be much appreciated
[Updated on: Fri, 07 February 2014 12:53] by Moderator
Re: change query depending on locale [message #1240442 is a reply to message #1223515] Thu, 06 February 2014 08:19 Go to previous messageGo to next message
any hint?
Re: change query depending on locale [message #1240476 is a reply to message #1240442] Thu, 06 February 2014 09:53 Go to previous messageGo to next message
I don't think it is necessary to use a report parameter such "mylocale" here. You could try this:
In the query of your dataset, use a question mark like this:
Select * from table where country=?
Then in parameters section of the dataset, edit the parameter and just fill the "Default value" property with the expression you mentionned:
I hope this helps!
Re: change query depending on locale [message #1240557] Thu, 06 February 2014 14:07 Go to previous messageGo to next message
Hi donino
i'm afraid I gave a wrong example.
The real query is more a thing like this:
If locale is French, select French_name, french_description from product
If locale is English, select englîsh_name, english_description from product
I can get the locale but I'm stuck on getting the proper SQL to work in the dataset
Thanks in advance
[Updated on: Thu, 06 February 2014 15:58] by Moderator
Re: change query depending on locale [message #1240983 is a reply to message #1240557] Fri, 07 February 2014 04:50 Go to previous messageGo to next message
In this case you need to change your query depending on the value of the locale. In the beforeOpen script of the dataset. You probably need to use aliases so that BIRT can still match columns dataset with the result of the query. It would be something like:
var mylocale=reportContext.getLocale().toString().substr(1,2);
if (mylocale=="fr"){
    this.queryText="select French_name as name, french_description as description from product";
}else if(mylocale=="en"){
    this.queryText="select englîsh_name as name, english_description as description from product";
Let me know if it helps
[Updated on: Fri, 07 February 2014 04:54] by Moderator
Re: change query depending on locale [message #1241250 is a reply to message #1240983] Fri, 07 February 2014 12:52 Go to previous messageGo to next message
So easy I feel stupid right now Sad
worked perfectly.
Thanks domino
Re: change query depending on locale [message #1371736 is a reply to message #1240476] Wed, 21 May 2014 10:16 Go to previous message
> I hope this helps!
Jose,
You could use something like this in the beforeOpen() of the data source
var locale = reportContext.getLocale().toString()
locale = locale.substr(3,4);
this.queryText = "select * from customers where country = '" + locale + "'";
Previous Topic:I need some help with few things - drill, hyperlinks etc.
Next Topic:BIRT Report ppt is not opening in MS Office 2013
Current Time: Wed Jul 23 12:58:13 EDT 2025
Powered by FUDForum. Page generated in 0.16076 seconds
