Home » Eclipse Projects » Eclipse 4 » Migration an Eclipse 3.x RCP application to E4: product problem(rcp product)
Migration an Eclipse 3.x RCP application to E4: product problem [message #1239230] Mon, 03 February 2014 12:58 Go to next message
I am working on project developed in Eclipse Helios, migrating from Eclipse 3.x to Eclipse 4 (in Luna release), when i run RCP application, as "run a product" the following errors on stack trace is shown:
org.eclipse.core.runtime.AssertionFailedException: null argument:
at org.eclipse.core.runtime.Assert.isNotNull(Assert.java:85)
at org.eclipse.core.runtime.Assert.isNotNull(Assert.java:73)
at org.eclipse.jface.resource.ColorRegistry.put(ColorRegistry.java:308)
at org.eclipse.jface.resource.ColorRegistry.put(ColorRegistry.java:287)
at org.eclipse.ui.internal.themes.ThemeElementHelper.installColor(ThemeElementHelper.java:311)
at org.eclipse.ui.internal.themes.ThemeElementHelper.populateRegistry(ThemeElementHelper.java:172)
at org.eclipse.ui.internal.Workbench$28.runWithException(Workbench.java:1665)
at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run(StartupThreading.java:31)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:136)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4145)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3762)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2706)
at org.eclipse.ui.internal.Workbench.access$7(Workbench.java:2614)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:609)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:565)
at xx.yyy.zzzz.Application.start(Application.java:42)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:109)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:80)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:372)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:226)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:636)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:591)
at org.eclipse.equinox.launcher.Main.run(Main.java:1450)
at org.eclipse.equinox.launcher.Main.main(Main.java:1426)
In the ".metadata\.plugin" folder, the folders were NOT created:
- org.eclipse.core.runtime
- org.eclipse.e4.workbench
- org.eclipse.ui.workbench
Any suggestions?
Thanks in advance.
Re: Migration an Eclipse 3.x RCP application to E4: product problem [message #1239828 is a reply to message #1239230] Wed, 05 February 2014 01:23 Go to previous messageGo to next message
I have attached one pdf which has steps to migrate from 3.x to 4.x and to create e4 application. You can verify in case you missed something.
I hope it will help
Divya
[Updated on: Wed, 05 February 2014 01:26] by Moderator
Re: Migration an Eclipse 3.x RCP application to E4: product problem [message #1240038 is a reply to message #1239828] Wed, 05 February 2014 10:23 Go to previous messageGo to next message
Hi Divya,
thanks very much, your document marked is really interessing.
But my dream (Sad)if it possibile, to do this migration without any change the code of the my project.
By observing the eclipse stack trace, It seems that my project is using some kind of color, which is no longer supported, but I can not have more details about kind of error.
bye,
Pina
Re: Migration an Eclipse 3.x RCP application to E4: product problem [message #1240290 is a reply to message #1240038] Thu, 06 February 2014 01:24 Go to previous messageGo to next message
Migration without any change of code Confused I don't know. May be it depends. In my case when I migrated using compatibility layer then also I had to put some code patches here and there to make my code running.
Regarding this specific NPE I am not sure just check what exactly is coming null and why is it so? you can also debug the same code in 3.x to find out how it was running fine there.
Divya
Re: Migration an Eclipse 3.x RCP application to E4: product problem [message #1240523 is a reply to message #1240290] Thu, 06 February 2014 12:18 Go to previous message
The error raised in Kepler depends on the management of custom themes in my project.
I am using "org.eclipse.ui.theme" extension point to customize colors in my views with the follwing theme category structure:
I Attach my custom plugin.xml file used and a screenshot during debug of my code.
You can see debugging of the code in the screenshot attached what happens when the
symbolic name is the "ColorBkgStepInfo" value, no value is bind to variable "ColorData".
Indeed the plugin.xml shows the assigned value:
<colorDefinition
categoryId="AppsColors"
defaultsTo="255,250,250"
id="ColorBkgStepInfo"
isEditable="true"
label="Step Info Background Color">
<description>
Background color for the step info area.
</description>
</colorDefinition>
This works fine in Helios release, and now in Kepler it raise an exception.
I'd appreciate any help/suggestion on that point.
Pina
  • Attachment: BugThemeEx.PNG
    (Size: 198.28KB, Downloaded 301 times)
  • Attachment: plugin.xml
    (Size: 38.54KB, Downloaded 318 times)
[Updated on: Thu, 06 February 2014 12:21] by Moderator
Previous Topic:e4 CSS with Toolbars, MenuBar and groups
Next Topic:Disabled Tool- and Menu-Items when adding programmatically
Current Time: Sat Jul 26 21:31:44 EDT 2025
Powered by FUDForum. Page generated in 0.27274 seconds
