Home » Eclipse Projects » Eclipse 4 » Disabled Tool- and Menu-Items when adding programmatically
Disabled Tool- and Menu-Items when adding programmatically [message #1239873] Wed, 05 February 2014 03:41 Go to next message
I try to migrate an existing e3-Application, where ToolItems and MenuItems are added programmatically to a part. In another post of I've found the solution to add the HandlerProcessingAddon to the Model but did not have success. The items are still disabled. As I don't have an Application.e4xmi know, because of migration, I have to add it programmatically.
I tried it as follows:
     * Register the HandlerProcessingAddon programmatically, because I don't have one yet.
    private void registerHandlerProcessingAddon() {
        MAddon addon = MApplicationFactory.INSTANCE.createAddon();
        addon.setElementId("org.eclipse.e4.ui.workbench.handler.model");
        addon.setContributionURI("bundleclass://org.eclipse.e4.ui.workbench/org.eclipse.e4.ui.internal.workbench.addons.HandlerProcessingAddon");
        application.getAddons().add(addon);
     * Create and register the command and the handler.
     * @return the command
    private MCommand createAndRegisterCopyCommandAndHandler() {
        MCommand command = MCommandsFactory.INSTANCE.createCommand();
        command.setElementId("theCommandId");
        command.setCommandName("theCommandName");
        application.getCommands().add(command);
        MHandler handler = MCommandsFactory.INSTANCE.createHandler();
        handler.setElementId(IWorkbenchCommandConstants.EDIT_COPY);
        handler.setCommand(command);
        handler.setContributorURI("bundleclass://org.eclipse.ui.ide/org.eclipse.ui.internal.views.markers.MarkerCopyHandler");
        application.getHandlers().add(handler);
        return command;
    private void addCopyToolItem(MCommand command) {
        MHandledToolItem toolElement = MMenuFactory.INSTANCE.createHandledToolItem();
        toolElement.setElementId("theElementToTest");
        toolElement.setIconURI("platform:/plugin/pluginName/icons/detail.png");
        toolElement.setCommand(command);
        toolElement.setVisible(true);
        toolElement.setEnabled(true);
        toolElement.setToBeRendered(true);
        MToolBar toolbar = part.getToolbar();
        toolbar.getChildren().add(toolElement);
        toolbar.setVisible(true);
        toolbar.setOnTop(true);
        toolbar.setToBeRendered(true);
Is there anything wrong in the code??? I thought adding the addon solves the problem. Tool- and MenuItems added directly in the model are working fine.
Re: Disabled Tool- and Menu-Items when adding programmatically [message #1239883 is a reply to message #1239873] Wed, 05 February 2014 04:00 Go to previous messageGo to next message
I'm a bit suprised that you don't have an Application.e4xmi are you sure
you are using e(fx)clipse and don't want the e4?
Tom
> http://www.eclipse.org/forums/index.php/t/550344/ of I've found the
> programmatically.
> don't have one yet. */
> * * @return the command
> return command;
> fine.
Re: Disabled Tool- and Menu-Items when adding programmatically [message #1239892 is a reply to message #1239883] Wed, 05 February 2014 04:20 Go to previous messageGo to next message
It's the aim that the application has the same functionality after the migration process and the compatibility-layer should not be required. So I know that I require the Application.e4xmi later. Now I migrate all my parts with the and DIViewPart, which works really good. I hope to migrate everything without loosing any features and then introduce the Application.e4xmi.
Is there another or better way for migration??
By the way I experiment with the Application.e4xmi in an own SampleE4Project.
[Updated on: Wed, 05 February 2014 04:23] by Moderator
Re: Disabled Tool- and Menu-Items when adding programmatically [message #1239893 is a reply to message #1239892] Wed, 05 February 2014 04:23 Go to previous messageGo to next message
I repeat my question and I'm now 100% sure that you are at the wrong forum!
You want the e4 forum but are asking at the efxclipse one which deals
about e4 on JavaFX and JavaFX at Eclipse in general.
Tom
> Application.e4xmi.
Re: Disabled Tool- and Menu-Items when adding programmatically [message #1240295 is a reply to message #1239893] Thu, 06 February 2014 01:27 Go to previous messageGo to next message
Oh, I'm sorry that I placed my question into the wrong forum. I hope someone can move my topic into the correct forum.
Re: Disabled Tool- and Menu-Items when adding programmatically [message #1240353 is a reply to message #1240295] Thu, 06 February 2014 04:29 Go to previous messageGo to next message
You need to repo to the e4 forum!
Tom
Re: Disabled Tool- and Menu-Items when adding programmatically [message #1240858 is a reply to message #1240353] Fri, 07 February 2014 01:29 Go to previous message
I was looking now, if there is a newer Kepler-Eclipse available, but there isn't. So I hope someone has a hint, how programmatically adding tool and menuitems in e4.
Previous Topic:Migration an Eclipse 3.x RCP application to E4: product problem
Next Topic:Re: Proposed improvement to Eclipse
Current Time: Fri Jul 25 23:45:33 EDT 2025
Powered by FUDForum. Page generated in 0.08312 seconds
