Creating Xtext release locally [message #1239212] |
Mon, 03 February 2014 11:50  |
Hi all, I'm trying to create a release of xtext to be used internally because there are some blocking issues in 2.5.0 that will be fixed in 2.5.1 but until then the are still blocking progress.
I have followed the instructions in the contributor project, so I have buckminster and everything set up. I'll cherry pick whatever modifications I need and then want to create the internal release.
Can someone please describe the steps I have to follow to get this done? Especially the eclipse plugins, but if there are instructions for the maven side too, then I'd be happy to hear those, as well.
Andras
Re: Creating Xtext release locally [message #1239701 is a reply to message #1239696] |
Tue, 04 February 2014 15:47  |
Awesome! An Eclipse committer friend of mine suggested the same when we talked today. As long as there are no regressions, it should be fine. I didn't know about this feature.
Andras
PS: the other machine turned out to use Java 6 which caused the Xtend compiler to fail in various ways. Correcting this setting solved all issues and the new version solved the blocking issues as well. Thanks again!
FUDForum. Page generated in 0.04643 seconds
