Home » Archived » EMF-IncQuery » How to prevent traversal of objects
How to prevent traversal of objects [message #1239503] |
Tue, 04 February 2014 05:22  |
Hi there,
i am trying to work with incquery and a lot of model data (about 500k objects). When accessing the first pattern via API (IncQueryEngine initalized with Root-Model-Object), it trys to cache/traverse all objects. That's not possible, because the model is too big for the memory and even with enough memory, it would take too long.
Is there a way to prevent incquery from caching/traversing given objects, that are not needed for any patterns (e.g. some objects contain about 2-5k other objects, the contained ones are not of interest) or are there any best practices how to design the patterns that only the objects of interest are traversed.
My next question would be if it is possible to persist the cached information in the database? I wouldn't want to traverse all objects again at each startup of the application.
Thanks for any Help or Hints.
Greets
Christian Mohr
Re: How to prevent traversal of objects [message #1239508 is a reply to message #1239503] |
Tue, 04 February 2014 05:37   |
Hi Christian,
in short, there are currently no real solutions to your problem in EMF-IncQuery, only some workarounds.
In order to EMF-IncQuery work (at all because of the used Rete algorithm), a cache needs to be initialized with all model elements in the search scope. This scope can contain relevant elements of a ResourceSet, a Resource or the elements contained in a single model element. Last week we had a meeting when we were talking about introducing a programmable traversal option (https://wiki.eclipse.org/EMFIncQuery/DeveloperMeetingMinutes/Meeting20140129#Action_plan), but the corresponding ticket has not been created yet, and don't have any concrete plans when this will be implemented.
About serializing the caches - it would be a nice idea, yes, but it would require serialization and deserialization support that also has not been implemented yet in our engine.
The only thing I can come up for your problem is to use EObject scope if possible (but if I understood your problem correctly, that might not be the case), or wait for the index to load.
If that is still unacceptable, you could also try program directly over the base indexer component (https://wiki.eclipse.org/EMFIncQuery/UserDocumentation/API/BaseIndexer), that builds much smaller indexes and finishes traversal much faster; however you cannot use the pattern specifications and still need to traverse the model each time.
I hope, something along these line help,
Zoltán
Re: How to prevent traversal of objects [message #1239580 is a reply to message #1239503] |
Tue, 04 February 2014 09:20  |
To put it in simpler terms:
Any search engine would need to traverse your entire model, in order to evaluate global queries. How should the engine know "in advance" that certain subtrees are not of interest?
That being said, EMF-IncQuery provides three matcher scopes (ResourceSet, Resource and EObject) that you can use to restrict traversal. Note however that _caching_ will only be done for those types that are actually contained in your queries, so no unnecessary resources are used.
For more details on related topics and best practices, I highly recommend to read the FAQ:
http://incquery.net/incquery/faq
For specific questions regarding the optimization of patterns, we are glad to help here, if you provide more details. 500k of objects is not too big a model, so with some optimization, I'm certain the execution time can be brought down to an acceptable level.
Quote:My next question would be if it is possible to persist the cached information in the database? I wouldn't want to traverse all objects again at each startup of the application.
We've already had similar feature requests, and the core infrastructure for this is already present, we just did not wire it to the API yet. I couldn't find the bugzilla, so if you feel like it, please drop us a ticket on this topic.
regards
Current Time: Thu Sep 11 06:13:45 EDT 2025
Powered by FUDForum. Page generated in 0.03909 seconds
