| Compatibility with EclipseME [message #12395] | Tue, 29 January 2008 17:15  |  |
| Eclipse User  |  |  |  |  | Originally posted by: sergei.synopsia.net
 Are any versions of Subversive plugin compatible with EclipseME 1.7.7? If
 yes, which ones? Otherwise, could you recommend some other SVN plugin?
 Sergei
| org.eclipse.pde.ui (was: Compatibility with EclipseME) [message #12404 is a reply to message #12395] | Wed, 30 January 2008 17:32   |  |
 Hello again,
 I working with Motodev Studio, which is based on Eclipse 3.3 with
 EclipseME 1.7.7. Tried installing subversive, which required Mylyn Bridge,
 which in turn requires something else -- here is the error message:
 Mylyn Bridge: PDE, CVS and Ant (2.3.0.I20080125-1200) requires plug-in
 "org.eclipse.pde.ui".
 Can someone please point me to where I might be able to get that?
 Thanks in advance.
 Sergei S. wrote:
 > Sergei
| Re: org.eclipse.pde.ui [message #12413 is a reply to message #12404] | Wed, 30 January 2008 23:50   |  |
| Eclipse User  |  |  |  |  | Sergei S. wrote: > Hello again,
 > Bridge, which in turn requires something else -- here is the error message:
 > Thanks in advance.
 > Sergei S. wrote:
 >> Hi,
 >> If yes, which ones? Otherwise, could you recommend some other SVN plugin?
 >> Thanks,
 >> Sergei
 I am not sure, what else is behind EclipseME 1.7.7 (I just finished an
 article about Mobile Eclipse Development, so I looked at it, but not
 every single Plugin it uses ;-) but you probably need to check older
 (propriatory) versions of Subversive still hosted by Polarion.
 Either their UpdateManager still works, or they can be downloaded somehow.
 Of course if it was totally incompatible, the alternative SVN Team
 client by ColabNet (Subclipse or so I think?) might work, too.
FUDForum. Page generated in 0.04303 seconds
