Home » Language IDEs » C / C++ IDE (CDT) » Help: "Print Size" stopped working("Print Size" was working before, but it stopped and I can't figure out why)
Help: "Print Size" stopped working [message #854409] Mon, 23 April 2012 19:54 Go to next message
I have Eclipse running with an ARM toolchain using Sourcery Codebench Lite. Until yesterday, when I compiled, it would end up calling arm-none-eabi-size to print out the size of the compiled code. It stopped doing that, and I can't figure out why.
If I run arm-none-eabi-size from a command line, it works. The project's Tool Settings shows ARM Sourcery GNU Print Size and it's configured correctly. The "Additional Tools" under Tool Settings has Print Size checked. Shouldn't that do the trick?
Build Steps does not have anything set for the Post-build steps. I suppose I could put an invocation of arm-none-eabi-size there, but it shouldn't be necessary, should it?
arm-none-eabi-size stopped working for all projects in two different workspaces, so something really fundamental must've broken.
What else can I look for?
Thank you,
Bob
Re: Help: "Print Size" stopped working [message #856540 is a reply to message #854409] Wed, 25 April 2012 15:17 Go to previous messageGo to next message
Anyone??
Re: Help: "Print Size" stopped working [message #857133 is a reply to message #856540] Thu, 26 April 2012 05:14 Go to previous messageGo to next message
On 4/25/2012 9:17 PM, Bob Alexander wrote:
> Anyone??
Eric Raymond has lots of useful tips how to research problems and get
maximum response for questions (if still necessary):
http://catb.org/~esr/faqs/smart-questions.html
Re: Help: "Print Size" stopped working [message #1239334 is a reply to message #857133] Mon, 03 February 2014 19:37 Go to previous messageGo to next message
+1 on this issue: for some inexplicable reason, the Eclipse tool chain has stopped making the command line call that "Print Size" check box should invoke. I've looked all over for a setting in Eclipse that might trump the toolchain settings, given "Print Size" is definitely checked. I can tell the call is never made to arm-none-eabi-size.exe because, when I modify the extension "size" to "XXX", there is no failure to find the executable. Same for objcopy!
I'm using:
ARM GNU plugin for Eclipse,
Eclipse Version: Kepler Service Release 1 Build id: 20130919-0819.
[Updated on: Thu, 06 February 2014 12:14] by Moderator
Re: Help: "Print Size" stopped working [message #1299168 is a reply to message #1239334] Wed, 16 April 2014 15:45 Go to previous messageGo to next message
Bob,
did you find a solution for Print Size ?
Robert
Re: Help: "Print Size" stopped working [message #1313154 is a reply to message #1299168] Thu, 24 April 2014 14:38 Go to previous message
On recent update of various Eclipse modules and plugins, this problem went away and printsize started working again.
I can't be sure exactly which update fixed the problem, but my best guess was that on 3/7/14 I updated my pertinent installation to look like this, which is working smoothly:
C/C++ Development Tools 8.3.0.201402142303
C/C++ GDB Hardware Debugging 8.3.0.201402142303
Eclipse Standard/SDK 2.0.2.20140224-0000
Eclox 0.8.0
Embedded Systems Register View (SFR) 0.2.4
EmbSysRegView Data 0.2.4.r160
GNU ARM C/C++ Cross Compiler Support 1.8.1.201402180751
GNU ARM C/C++ Freescale Project Templates 1.2.1.201402180751
GNU ARM C/C++ STM32Fx Project Templates 1.7.2.201402180751
GNU ARM J-Link Debugging Support 1.4.2.201402180751
GNU ARM OpenOCD Debugging Support 1.1.1.201402180751
Alex G.
[Updated on: Thu, 24 April 2014 14:39] by Moderator
Previous Topic:parallel debugging problem
Next Topic:PyDev in C / C++ Eclipse Version
Current Time: Thu Jul 24 22:59:03 EDT 2025
Powered by FUDForum. Page generated in 0.07483 seconds
