Running AGR on a different workbench [message #123739] |
Fri, 22 February 2008 03:17 |
Originally posted by: nyakar.cisco.com
Hello
I would be grateful if you could give me some help regarding a TPTP issue
I am facing for a while now.
My problem is that although I try to run an AGR test over an eclipse
workbench which is produced out of the code I want to examine, it only
opens the REGULAR DEVELOPMENT eclipse development workbench.
The AGR test was imported to the same workspace the code I want to examine
is in.
I defined a deployment file that describes the context of the produced
eclipse workbench. Those are the main .location file properties I
configured:
- ECLIPSE_STARTUP_PATH = path to the
eclipse\plugins\org.eclipse.equinox.launcher_1.0.1.R33x_v200 70828.jar
file of the produced eclipse workbench
- eclipse location = path of the eclipse installation of the new eclipse
workbench
- workspace data = the absolute path of the WORKSPACE the produced eclipse
WORKBENCH uses
- all other properties have been copied from the run dialog of the
candidate,
besides the plugins to use, which doesn't include the plugins defined in
that run dialog (why can't I pick them from the location file? is it
important??)
I would appreciate any help given to me on that matter.
Nadav
FUDForum. Page generated in 0.08303 seconds
