Home » Archived » Test and Performance Tools Platform (TPTP) » Issue is ChoiceSelectionCommand
Issue is ChoiceSelectionCommand [message #123572] Wed, 20 February 2008 14:38 Go to next message
Hi All,
In my dialog i am using ComboBoxCellEditor. So while recording the test
case i select one of the item which is displayed in the editor.
But while running the script i am gettin the following error.
org.eclipse.core.runtime.CoreException
Error while executing a macro command: MacroCommand [choice-select, line
22]
java.lang.ArrayIndexOutOfBoundsException: 0
at
org.eclipse.tptp.test.auto.gui.internal.commands.ChoiceSelec tionCommand.playback(ChoiceSelectionCommand.java:143)
I don't know why i am getting this error message.
Pushparaj
Re: Issue is ChoiceSelectionCommand [message #123587 is a reply to message #123572] Wed, 20 February 2008 21:33 Go to previous messageGo to next message
Hi All,
Also i am getting the same error wherever i am using cell editors.
If its a text TextCellEditor, this error is coming in ModifyCommand.
Is TPTP is not supporting cell editors?
Pushparaj.
Re: Issue is ChoiceSelectionCommand [message #123677 is a reply to message #123587] Thu, 21 February 2008 09:14 Go to previous messageGo to next message
As I know the cell editors in JFace Table is not supported in current
AGR version. We did an enhancement to get it supported, but this needs
addition attributes in the <command> element.
Does anyone else also like to have this enhancement?
Jimmy Jin
Pushparaj wrote:
> Hi All,
> Pushparaj.
Re: Issue is ChoiceSelectionCommand [message #123702 is a reply to message #123677] Thu, 21 February 2008 10:31 Go to previous messageGo to next message
Hi Jimmy Jin,
Can you please explain what enhancement/attribute i should do to make it
working?
Becuase in my application we are using celleditor in most of our viewers.
So without this fix ican't continue my work.
Is there any workaround for this issue?
Please help me to resolve this issue.
Re: Issue is ChoiceSelectionCommand [message #123817 is a reply to message #123702] Sun, 24 February 2008 08:06 Go to previous messageGo to next message
Hello, Pushparaj,
The key is to get the cell editor activated before the modify or choice
select command is executed.
The enhancement includes adding some attributes to the <command>
element, to include the identify of the parent of the current ComboBox
or Text, if it is a Table.
* When recording, for the modify and choice selection command, if the
according control's parent is a Table, then include parent Table's
identify into the attributes. Also include the column and row, which
this control is in, into the <command> element.
* When playback, if there is these parent control info in the modify and
choice select command and it's a Table, then try to send an mouse click
event to the Table with calculated mouse position, so that the editor in
the according cell can be activated.
I think this can also be workaround by adding a verification command
before your modify or choice select command. In the verification
command, you can find out the Table, and send it a proper mouse down
event to activate the cell editor.
Jimmy Jin
Pushparaj wrote:
> Hi Jimmy Jin,
> working? Becuase in my application we are using celleditor in most of
> our viewers. So without this fix ican't continue my work.
Re: Issue is ChoiceSelectionCommand [message #124265 is a reply to message #123817] Mon, 25 February 2008 21:20 Go to previous messageGo to next message
Hi Jimmy Jin,
Can i get this enhancement if i take the latest build ?.
Because i tried the workaround what you mentioned in your reply. I am not
facing any problem while recording the test case. But while running it is
going up to the verification method then it waits for sometime after that
i am getting some irrelevent error message(in line number 3).
So if you have the plan to add your enhancement in near future i can wait
for this enhancement.
Pushparaj
Re: Issue is ChoiceSelectionCommand [message #124720 is a reply to message #124265] Thu, 28 February 2008 09:08 Go to previous messageGo to next message
Hello, Pushparaj,
I will suggest you debug the verification method to see what the problem
it is. The enhancement needs some modification to the generated XML
script, so it may take me some time to submit it (also including the
modification to the document, which I've never done before). Also even
it's available in some version of AGR, I'm not sure if you can use the
compatible Eclipse version (for example 3.4).
You can post your verification method here, and I can also help you to
have a look.
Jimmy Jin
Pushparaj wrote:
> Hi Jimmy Jin,
> not facing any problem while recording the test case. But while running
> it is going up to the verification method then it waits for sometime
> after that i am getting some irrelevent error message(in line number 3).
> wait for this enhancement.
> Pushparaj
Re: Issue is ChoiceSelectionCommand [message #124946 is a reply to message #124720] Sat, 01 March 2008 12:14 Go to previous message
Hi Jimmy Jin,
If it is working in some AGR version I am ready to use the compatible
eclipse version (3.4).
In my verification method I didn't written any code. It is blank.
Pushparaj
Previous Topic:problem with profiling RCP application ..
Next Topic:Is there any training provided for tptp
Current Time: Wed Jul 23 19:30:06 EDT 2025
Powered by FUDForum. Page generated in 0.05306 seconds
