Home » Archived » Sapphire » Radio Button Group with Possible Value Service
Radio Button Group with Possible Value Service [message #1236476] Mon, 27 January 2014 05:02 Go to next message
I'm wondering if there exists a way for using the Radio Button Group in conjunction with the Possible Value Service. I only find samples for using it with enumerations, which is ok for static content, but not for dynamic use cases. I've tried to use it, but sapphire ignores the style hint.
Especially for dialogs, there currently seems to be no alternative to Tables for displaying dynamic structures containing nested details. And for small structures it would be great using radio button groups.
Is that something for the 8.0 release?
Andreas
Re: Radio Button Group with Possible Value Service [message #1236491 is a reply to message #1236476] Mon, 27 January 2014 05:44 Go to previous messageGo to next message
Hey Andreas,
I have done exactly that. I have a possible values service extension hooked up to a radio button group. See the code here:
https://github.com/liferay/liferay-ide/blob/master/tools/plugins/com.liferay.ide.project.ui/src/com/liferay/ide/project/ui/wizard/PossibleValuesAuxTextProvider.java
https://github.com/liferay/liferay-ide/blob/master/tools/plugins/com.liferay.ide.project.ui/src/com/liferay/ide/project/ui/wizard/PossibleValuesRadioButtonsGroupBinding.java
https://github.com/liferay/liferay-ide/blob/master/tools/plugins/com.liferay.ide.project.ui/src/com/liferay/ide/project/ui/wizard/PossibleValuesRadioPropertyEditorPresentation.java
All of this code is activated via a sdef setting here:
https://github.com/liferay/liferay-ide/blob/master/tools/plugins/com.liferay.ide.project.ui/src/com/liferay/ide/project/ui/wizard/NewLiferayPluginProjectWizard.sdef#L185-L186
which points to this class
https://github.com/liferay/liferay-ide/blob/master/tools/plugins/com.liferay.ide.project.ui/src/com/liferay/ide/project/ui/wizard/PortletFrameworkPropertyEditorPresentationFactory.java
This factory class using the "PossibleValuesRadioPropertyEditorPresentation"
Re: Radio Button Group with Possible Value Service [message #1236493 is a reply to message #1236491] Mon, 27 January 2014 05:45 Go to previous messageGo to next message
See the attached screenshot. Both of the radio groups in this sapphire wizard page are supported by the possible values radio button presentation.
Re: Radio Button Group with Possible Value Service [message #1236496 is a reply to message #1236493] Mon, 27 January 2014 05:53 Go to previous messageGo to next message
Looks exactly what I was looking for. Thanks for this quick and good answer!
I will check it out more in detail.
If possible due to IP stuff: Isn't that worth to be contributed to the master branch?
Re: Radio Button Group with Possible Value Service [message #1236497 is a reply to message #1236496] Mon, 27 January 2014 05:55 Go to previous messageGo to next message
If Konstantin is interested in having this in sapphire 8, i'm happy to do the leg work to get it into sapphire UI
Re: Radio Button Group with Possible Value Service [message #1236499 is a reply to message #1236497] Mon, 27 January 2014 05:56 Go to previous messageGo to next message
I think in general the concern might be that 'possible values' service could be hundreds of items. So a radio button group hooked to any possible values service could get crazy. But in my situation I know that the possible values wil always be a manageable number. Since sapphire is flexible enough to do it outside of sapphire-ui in adopter plugins, i didn't originally push to have this be a part of sapphire framework.
[Updated on: Mon, 27 January 2014 05:58] by Moderator
Re: Radio Button Group with Possible Value Service [message #1236598 is a reply to message #1236499] Mon, 27 January 2014 11:32 Go to previous messageGo to next message
I would certainly welcome a contribution of this feature to Sapphire. The best way to do this is to rework the existing RadioButtonGroupPropertyEditorPresentation so that it works with the PossibleValuesService instead of assuming enums, similarly to how PopUpListFieldPropertyEditorPresentation is implemented. Please open an enhancement request to track this work further.
Re: Radio Button Group with Possible Value Service [message #1237755 is a reply to message #1236598] Thu, 30 January 2014 09:01 Go to previous messageGo to next message
Enhancement Request opened: https://bugs.eclipse.org/bugs/show_bug.cgi?id=426994
Re: Radio Button Group with Possible Value Service [message #1242755 is a reply to message #1237755] Sun, 09 February 2014 22:35 Go to previous message
I'll try to get this contributed this month.
Previous Topic:Expression in PossibleValues.invalidValueMessage()
Next Topic:FormPage messages
Current Time: Tue Oct 28 16:16:18 EDT 2025
Powered by FUDForum. Page generated in 0.04777 seconds
