A subtype of ScriptTask [message #1236564] |
Mon, 27 January 2014 09:50  |
Hi.
I need to have a new subtype of ScriptTask - called for instance. MyScriptTask.
The difference is that the script task is persisted with an additional attribute:
<bpmn2:scriptTask mynamespace:type="mine">
I see what I have to do to persist it the way I want, but I don't know how to create a new element in the Pallete that will also correspond to a Script task.
How do I manage to do this?
I believe I must to implement a new feature container for script task where the script icon or "my" icon is choosen accordingly with the existence of mynamespace:type="mine" property. I also believe I shold not in this case to implement a custom Task. Am I wrong?
But how should I proceed in what concerns to palette??
rui
Re: A subtype of ScriptTask [message #1236908 is a reply to message #1236746] |
Tue, 28 January 2014 06:09   |
Thanks.
The second problem occurs because in org.eclipse.bpmn2.modeler.ui.features.activity.task.CustomShapeFeatureContainer
the icon is added only if addFeatureDelegate hasn't added one yet.
public PictogramElement add(IAddContext context) {
PictogramElement pe = addFeatureDelegate.add(context);
// make sure everyone knows that this PE is a custom task
if (pe!=null)
Graphiti.getPeService().setPropertyValue(pe,CUSTOM_ELEMENT_ID,getId());
// add an icon to the top-left corner if applicable, and if the implementing
// addFeatureDelegate hasn't already done so.
String icon = customTaskDescriptor.getIcon();
if (icon!=null && pe instanceof ContainerShape) {
boolean addImage = true;
ContainerShape containerShape = (ContainerShape)pe;
GraphicsAlgorithm ga =
GraphicsAlgorithm)AbstractBpmn2AddFeature.getGraphicsAlgorithm(containerShape);
for (PictogramElement child : containerShape.getChildren()) {
if (child.getGraphicsAlgorithm() instanceof Image) {
addImage = false;
break;
if (ga!=null) {
for (GraphicsAlgorithm g : ga.getGraphicsAlgorithmChildren()) {
if (g instanceof Image) {
addImage = false;
break;
else
addImage = false;
if (addImage) {
Image img = CustomTaskImageProvider.createImage(customTaskDescriptor, ga, icon, 24, 24);
Graphiti.getGaService().setLocationAndSize(img, 2, 2, 24, 24);
return pe;
Thanks again
Re: A subtype of ScriptTask [message #1237097 is a reply to message #1237093] |
Tue, 28 January 2014 16:25  |
1.Yes, I noticed that the description was the one shown in the Tab. And not the one used to instantiate create feature.
2.Yes I can code around that somehow. For now I've just hacked the plugin code. I'll try later to work around that in feature container if it is possible.
Thanks Bob
FUDForum. Page generated in 0.05602 seconds
