Home » Modeling » QVT-OML » Setting a configuration property from Java
| Setting a configuration property from Java [message #1235519] |
Fri, 24 January 2014 10:11  |
Hello everyone,
I'm writing a Operational QVT which will use a "configuration property"
In Eclipse's run Configuration for the transformation i can see my configuration property and i can set the value as expected.
Now i'm stuck trying to find a way to set this configuration property from Java, since i need to call the transformation from Java code.
I'm showing you my attempt, hoping that it's enough clear. I've reused an already available (and working) code:
private static void launchTransformation(String trURI, String trName,
boolean generateTrace, Resource chessModel, Resource feiModel, IProgressMonitor monitor) throws Exception{
String chessModelURIString = chessModel.getURI().toString();
String feiModelURIString = feiModel.getURI().toString();
String qvtTraceURIString = generateTrace ? chessModelURIString.substring(0,
chessModelURIString.lastIndexOf('.') + 1) + "qvtotrace" : null;
String trURIString = trURI;
ILaunchManager manager = DebugPlugin.getDefault().getLaunchManager();
ILaunchConfigurationType c = manager
.getLaunchConfigurationType(QvtLaunchConfigurationDelegate.LAUNCH_CONFIGURATION_TYPE_ID);
ILaunchConfigurationWorkingCopy instance = c.newInstance(null, trName);
instance.setAttribute(IQvtLaunchConstants.CLEAR_CONTENTS + "1", true);
instance.setAttribute(IQvtLaunchConstants.CLEAR_CONTENTS + "2", true);
instance.setAttribute(IQvtLaunchConstants.ELEM_COUNT, 2);
instance.setAttribute(IQvtLaunchConstants.FEATURE_NAME + "1", "");
instance.setAttribute(IQvtLaunchConstants.FEATURE_NAME + "2", "");
instance.setAttribute(IQvtLaunchConstants.MODULE, trURIString);
instance.setAttribute(IQvtLaunchConstants.TARGET_MODEL + "1", chessModelURIString);
instance.setAttribute(IQvtLaunchConstants.TARGET_TYPE + "1", "NEW_MODEL");
instance.setAttribute(IQvtLaunchConstants.TARGET_MODEL + "2", feiModelURIString);
instance.setAttribute(IQvtLaunchConstants.TARGET_TYPE + "2", "NEW_MODEL");
if (generateTrace){
instance.setAttribute(IQvtLaunchConstants.TRACE_FILE, qvtTraceURIString);
instance.setAttribute(IQvtLaunchConstants.USE_TRACE_FILE, generateTrace);
QvtTransformation qvtTransformation = new QvtInterpretedTransformation(
QvtLaunchConfigurationDelegateBase.getQvtModule(instance));
IStatus status = QvtLaunchConfigurationDelegateBase.validate(
qvtTransformation, instance);
if (status.getSeverity() > IStatus.WARNING) {
throw new CoreException(status);
EvaluationMonitor execMonitor = createMonitor();
Context context = QvtLaunchUtil.createContext(instance);
OutputStreamWriter s = new OutputStreamWriter(CHESSProjectSupport.CHESS_CONSOLE);
context.setLog(new WriterLog(s));
context.setMonitor(execMonitor);
//begin attempt
Map<String, String> configMap = new HashMap<String, String>();
Set<QvtConfigurationProperty> configProps = qvtTransformation.getConfigurationProperties();
for (QvtConfigurationProperty qvtConfProp : configProps) {
if(qvtConfProp.getName().equals("systemName")){
configMap.put(qvtConfProp.getName(), "attempt");
* "attempt" will be a String selected by a user through a dialog
* at run-time passed as parameter to this function
instance.setAttribute(IQvtLaunchConstants.CONFIGURATION_PROPERTIES, configMap);
//end attempt
QvtLaunchConfigurationDelegateBase.doLaunch(qvtTransformation,instance, context);
qvtTransformation.cleanup();
unfortunately the configuration property called "systemName" is null when i read it in the transformation.
I know i'm asking a lot, but it would be great if someone notices something wrong or missing in my attempt and could point it to me.
If you need further information, please tell me.
I apologize in advance if it has been already discussed, but i haven't found anything
Nicholas
| Re: Setting a configuration property from Java [message #1235527 is a reply to message #1235519] |
Fri, 24 January 2014 10:37   |
You can study the code just as well as I can. Or you can use a debugger
to conmopare what works.
But you're more likely to get takers if you provide a useable repro. See
http://wiki.eclipse.org/OCL/ForumNetiquette
Ed Willink
On 24/01/2014 15:11, nicholas pacini wrote:
> Hello everyone,
> "qvtotrace" : null;
> trName);
> "1", true);
> "2", true);
> "NEW_MODEL");
> feiModelURIString);
> "NEW_MODEL");
> if (generateTrace){
> qvtTraceURIString);
> //begin attempt
> through a dialog * at run-time passed as parameter to
> this function
> configMap);
> //end attempt
> found anything
> Regards,
> Nicholas
Current Time: Sat Nov 01 13:31:40 EDT 2025
Powered by FUDForum. Page generated in 0.04245 seconds
