Home » Modeling » EMF » EMF Eclipse Forms Editor
EMF Eclipse Forms Editor [message #1235227] Thu, 23 January 2014 16:28 Go to next message
I wanted to create Forms Editor for my emf model, then I stumbled upon EMF Eclipse Forms Editor and integrated into my project. The Forms Editor works quite well, however in my case I wanted forms editor to be the only editor that understands my model and removed all other editors such as Selection, Parent and Tree. Unfortunately without these editors loaded first menu action listeners do not work properly in Forms Editor. One example would be that only one instance of child can be created per editor being open, the other is if model allows only one child of Type A let's say, in context menu Type A menu is not disabled unless I restart the editor. I tried to debug this behavior and even added code to initialize ViewerPane during PartListener call:
protected void hideTabs() {
		if (getPageCount() == 2) {
			if (getContainer() instanceof CTabFolder) {
		          ((ViewForm)viewerPane.getControl()).getContent().setFocus();
				 viewerPane.showFocus(true);
				 setCurrentViewerPane(viewerPane);
				((FormEditor)this).setActivePage(ScrolledPropertiesPage.ID);
				((CTabFolder)getContainer()).setTabHeight(0);
Unfortunately none of my attempts worked. Has anybody utilized EMF Forms Editor before? Perhaps there is another working solution?
Alex
Re: EMF Eclipse Forms Editor [message #1235234 is a reply to message #1235227] Thu, 23 January 2014 16:50 Go to previous messageGo to next message
Did you have a look at the EMF Client Platform? It could be a "better alternative".
Alex Kravets wrote on Thu, 23 January 2014 22:28
Alex
Re: EMF Eclipse Forms Editor [message #1235391 is a reply to message #1235234] Fri, 24 January 2014 03:16 Go to previous messageGo to next message
Yes, the component of EMF Client Platform, which might be interesting
for you is EMF Forms:
http://eclipsesource.com/blogs/tutorials/emf-client-platform-how-to-customize-the-editor-layout/
Am 23.01.2014 22:50, schrieb Erdal Karaca:
> alternative".
>> Thanks,
>> Alex
Re: EMF Eclipse Forms Editor [message #1235541 is a reply to message #1235234] Fri, 24 January 2014 11:14 Go to previous messageGo to next message
Thanks Erdal,
I did look at ECP about six months ago and it is interesting project. However back then I don't think support for Eclipse Workspace was working properly, something that I was interested in.
Alex
Erdal Karaca wrote on Thu, 23 January 2014 16:50
Alex
Re: EMF Eclipse Forms Editor [message #1235546 is a reply to message #1235391] Fri, 24 January 2014 11:21 Go to previous messageGo to next message
Thanks Jonas,
I posted my interest in ECP and back then you mentioned that support for master detail view might be in plans. Was there any progress in this area?
Jonas Helming wrote on Fri, 24 January 2014 03:16
> alternative".
>> Thanks,
>> Alex
Re: EMF Eclipse Forms Editor [message #1236150 is a reply to message #1235541] Sun, 26 January 2014 06:09 Go to previous messageGo to next message
the support for the eclipse workspace is actually independant of EMF
Forms. However, if the workspace support for ECP did not work for you,
could you kindly report, what was not working?
Jonas
Am 24.01.2014 17:14, schrieb Alex Kravets:
> Thanks Erdal,
> Alex
>> alternative".
>> PartListener call:
>> > > Thanks,
>> > Alex
Re: EMF Eclipse Forms Editor [message #1236454 is a reply to message #1235546] Mon, 27 January 2014 03:50 Go to previous messageGo to next message
yes, master detail will be part of the 1.2 release, which will be
released in the beginning of next week. I am just writing the
documentation, I will post it here, so you can try it out.
Jonas
Am 24.01.2014 17:21, schrieb Alex Kravets:
> Thanks Jonas,
> I
> http://www.eclipse.org/forums/index.php/mv/msg/489640/1070556/#msg_1070556
>> > alternative".
>> >> Thanks,
>> >> Alex
Re: EMF Eclipse Forms Editor [message #1236650 is a reply to message #1236454] Mon, 27 January 2014 14:15 Go to previous messageGo to next message
Great! I will check it out.
Re: EMF Eclipse Forms Editor [message #1236652 is a reply to message #1236150] Mon, 27 January 2014 14:16 Go to previous messageGo to next message
I'll have to reinstall ECP and try it out again, but as I remember there were exceptions during finishing wizard with Eclipse Workspace selected.
Re: EMF Eclipse Forms Editor [message #1236877 is a reply to message #1236652] Tue, 28 January 2014 04:26 Go to previous messageGo to next message
It would be great, if you could test it again and report the error!
Jonas
Am 27.01.2014 20:16, schrieb Alex Kravets:
Re: EMF Eclipse Forms Editor [message #1236996 is a reply to message #1236877] Tue, 28 January 2014 10:37 Go to previous message
Jonas,
As of ECP 1.1.1 it's working fine. I was using 0.9 at the time I believe.
Alex
Jonas Helming wrote on Tue, 28 January 2014 04:26
Jonas
Previous Topic:JFace-Databinding
Next Topic:OOM, ResourceSet, unload(), reloads (Xtext), IReferableElementsUnloader..
Current Time: Sat Jul 26 23:42:55 EDT 2025
Powered by FUDForum. Page generated in 0.03446 seconds
