| HTTP Status 500 - JasperException [message #883530] |
Fri, 08 June 2012 14:08  |
Hi all,
I am an Eclipse newb, and have been given a web project to manage. I have consulted with the previous designer and have various tasks in Eclipse clearly outlined in order to publish content changes.
I preview the site locally on localhost:8080 and verify content changes there before exporting the project to .war and extracting it on the live site.
Last night the local server was running fine, then all of a sudden this morning, I am getting two different HTTP 500 Server errors that display randomly upon refreshing the index page:
Error #1:
HTTP Status 500 -
Type: Exception Report
Description: The server encountered an internal error () that prevented it from fulfilling this request.
Exception:
org.apache.jasper.JasperException: File "/WEB-INF/struts-tiles.tld" not found
org.apache.jasper.compiler.DefaultErrorHandler.jspError(DefaultErrorHandler.java:51)
org.apache.jasper.compiler.ErrorDispatcher.dispatch(ErrorDispatcher.java:409)
org.apache.jasper.compiler.ErrorDispatcher.jspError(ErrorDispatcher.java:116)
org.apache.jasper.compiler.TagLibraryInfoImpl.<init>(TagLibraryInfoImpl.java:160)
org.apache.jasper.compiler.Parser.parseTaglibDirective(Parser.java:430)
org.apache.jasper.compiler.Parser.parseDirective(Parser.java:499)
org.apache.jasper.compiler.Parser.parseElements(Parser.java:1558)
org.apache.jasper.compiler.Parser.parse(Parser.java:130)
org.apache.jasper.compiler.ParserController.doParse(ParserController.java:245)
org.apache.jasper.compiler.ParserController.parse(ParserController.java:101)
org.apache.jasper.compiler.Compiler.generateJava(Compiler.java:161)
org.apache.jasper.compiler.Compiler.compile(Compiler.java:326)
org.apache.jasper.compiler.Compiler.compile(Compiler.java:307)
org.apache.jasper.compiler.Compiler.compile(Compiler.java:295)
org.apache.jasper.JspCompilationContext.compile(JspCompilationContext.java:565)
org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:311)
org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServlet.java:308)
org.apache.jasper.servlet.JspServlet.service(JspServlet.java:259)
javax.servlet.http.HttpServlet.service(HttpServlet.java:729)
Error #2
HTTP Status 500 -
Type: Exception report
Message:
Exception:
org.apache.jasper.JasperException: Unable to load class for JSP
org.apache.jasper.JspCompilationContext.load(JspCompilationContext.java:599)
org.apache.jasper.servlet.JspServletWrapper.getServlet(JspServletWrapper.java:143)
org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:323)
root cause
java.lang.ClassNotFoundException: org.apache.jsp.index_jsp
java.net.URLClassLoader$1.run(Unknown Source)
java.security.AccessController.doPrivileged(Native Method)
java.net.URLClassLoader.findClass(Unknown Source)
org.apache.jasper.servlet.JasperLoader.loadClass(JasperLoader.java:131)
org.apache.jasper.servlet.JasperLoader.loadClass(JasperLoader.java:63)
org.apache.jasper.JspCompilationContext.load(JspCompilationContext.java:597)
note The full stack trace of the root cause is available in the Apache Tomcat/5.5.34 logs.
The file, "/WEB-INF/struts-tiles.tld" is indeed still there. I have a feeling something happened to the document root path as it appears to be looking in the wrong folder for files that don't exist there.
Does anyone have any ideas how to correct this?
Thank you.
FUDForum. Page generated in 0.07643 seconds
