Home » Archived » Jubula » Questions concerning the export and input of data
Questions concerning the export and input of data [message #1235537] Fri, 24 January 2014 11:05 Go to next message
Now that we have Jubula running, the following questions came to our minds:
a) Is it possible to export test results as excel sheets?
b) We have a bunch of textual regressiontests lying around. They consist of several steps and have the following form:
1. open login mask
2. enter password
3. submit
We would like to import those textual repräsentations as test case reference names. Is there a way we can do that within the ITE?
c) Is it possible to write test cases in a certain scripting language?
Any hints are much appreciated!
[Updated on: Fri, 24 January 2014 11:05] by Moderator
Re: Questions concerning the export and input of data [message #1236866 is a reply to message #1235537] Tue, 28 January 2014 04:06 Go to previous messageGo to next message
a) At the moment, test results can only be exported as HTML and XML.
b) There is almost certainly a way, but there is nothing out of the box to do that.
c) No, the only way to write tests is using the graphical way in the ITE.
For a) and b), there are various options that might help you - if you do something yourself, then add an enhancement with a patch and we'll review it. If you want the team to do something for you, then that's possible too - have a look at the sponsored development section on the portal. Obviously, this is also a possibility for c) as well, but the size of that would be much bigger as far as I can tell.
Alex
Re: Questions concerning the export and input of data [message #1237271 is a reply to message #1236866] Wed, 29 January 2014 04:20 Go to previous message
Thanks for the detailed answers. For now, we'll keep creating the tests with the ITE then.
Previous Topic:testexec hangs under linux
Next Topic:Jubula doesn't recognize drop down menu
Current Time: Fri Jul 25 22:56:11 EDT 2025
Powered by FUDForum. Page generated in 0.05765 seconds
