Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [org.eclipse.emf.codegen.ecore] Model code generation templates in Xtend?
[org.eclipse.emf.codegen.ecore] Model code generation templates in Xtend? [message #1235530] Fri, 24 January 2014 10:45 Go to next message
I was looking at the source code of EMF looking for templates used for code generation from a GenModel and I ended up looking inside the "org.eclipse.emf.codegen.ecore" plugin source code.
There, I found Java and JET templates (I assume the former is generated from the latter) and I was wondering:
  • Am I looking at the right templates? i.e. are these templates the ones used when generating code using "Right click->Generated Model code"?
  • If so, is there by any chance an Xtend version of these templates available somewhere ?
What I'm looking for is to generate the same code as Eclipse would do but by using Xtend.
BQ.
Re: [org.eclipse.emf.codegen.ecore] Model code generation templates in Xtend? [message #1235543 is a reply to message #1235530] Fri, 24 January 2014 11:15 Go to previous messageGo to next message
On 24-01-14 16:45, Bertrand Quenin wrote:
No, I don't think the EMF code generation ever moved beyond Xtend.
I made an attempt to move EMF to e4 generation, which at some point
would start to use Xtend, but that is really only the UI side of EMF.
see here: https://github.com/dzonekl/e4mf
What is it you are looking for to change in the templates?
> but by using Xtend.
> BQ.
Re: [org.eclipse.emf.codegen.ecore] Model code generation templates in Xtend? [message #1235544 is a reply to message #1235543] Fri, 24 January 2014 11:16 Go to previous messageGo to next message
>> Hi,
moved beyond JET that is....
>> but by using Xtend.
>> Thanks,
>> BQ.
Re: [org.eclipse.emf.codegen.ecore] Model code generation templates in Xtend? [message #1235563 is a reply to message #1235543] Fri, 24 January 2014 12:16 Go to previous message
Thanks for the info, I'm definitely gonna have a look at e4mf.
Why I'm looking for this? Because I want to have total control on how the code is generated.
BQ.
Previous Topic:EMF Facet - adding additional Attributes
Next Topic:[EEF] How to Generate Multiple Tabs
Current Time: Sat Jul 26 20:41:18 EDT 2025
Powered by FUDForum. Page generated in 0.03847 seconds
