Home » Eclipse Projects » GEF » CutRetargetAction missing
CutRetargetAction missing [message #123332] |
Sat, 20 March 2004 21:11  |
Originally posted by: phil.williams.toadmail.com
Just wondering why there is a CopyRetargetAction, PasteRetargetAction,
and DeleteRetargetAction but no CutRetargetAction.
Anyone care to comment?
Phil
Re: CutRetargetAction missing [message #123645 is a reply to message #123618] |
Mon, 22 March 2004 16:28   |
------=_NextPart_000_0252_01C4102A.B0463B00
Content-Type: text/plain;
charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printable
Reason for having copy/paste:
The copy/paste retarget actions that you see in GEF are used solely for =
the palette. And since the palette's static model is provided by GEF, =
they fall in the GEF domain. Like I said earlier, GEF uses those =
actions for accessibility purposes only: to copy something from the =
palette and then paste it in the diagram (hence, an accessible way of =
dragging something from the palette). GEF clients still have to provide =
their own actions for copying/pasting/cutting anything in their model. =
And you don't HAVE to hook into the retarget actions provided by GEF. =
You should be able to create your own retarget actions and everything =
should work just fine. But why do that when we have these two lying =
around?
Reason for not having cut:
You can't cut something from the palette.
"Phil Williams" <phil.williams@toadmail.com> wrote in message =
news:c3nco9$bq1$1@eclipse.org...
To follow Randy's mantra that I found several times in the newsgroup: =
Copying and pasting are the domain of the model. Therefore, you must =
implement your own actions that hook into the retarget actions. This is =
exactly what I do in my application. I use the retarget action to call =
my actions via the action IDs.
What I was wondering is why does GEF not have a CutRetargetAction but =
does have the others.
Phil
Pratik Shah wrote:
CopyRetargetAction (for CopyTemplateAction) is not copying in the sense =
as
selecting something in a logic diagram and copying it. It is there as =
an
accessible means to use the palette.
news:c3itcl$ou8$2@eclipse.org...
Phil
=20
Content-Type: text/html;
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD><TITLE></TITLE>
<META http-equiv=3DContent-Type =
content=3Dtext/html;charset=3DISO-8859-1>
<META content=3D"MSHTML 6.00.2800.1400" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY bgColor=3D#ffffff>
<DIV>Reason for having copy/paste:<BR>The copy/paste retarget actions =
that you=20
see in GEF are used solely for the palette. And since the =
palette's static=20
model is provided by GEF, they fall in the GEF domain. Like I said =
earlier, GEF uses those actions for accessibility purposes only: to copy =
something from the palette and then paste it in the diagram (hence, an=20
accessible way of dragging something from the palette). GEF =
clients still=20
have to provide their own actions for copying/pasting/cutting anything =
in their=20
model. And you don't HAVE to hook into the retarget actions =
provided by=20
GEF. You should be able to create your own retarget actions and =
everything=20
should work just fine. But why do that when we have these two =
lying=20
around?<BR><BR>Reason for not having cut:<BR>You can't cut something =
from the=20
palette.</DIV>
<DIV><FONT face=3DArial size=3D2></FONT> </DIV>
<BLOCKQUOTE dir=3Dltr=20
style=3D"PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; =
BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
<DIV>"Phil Williams" <<A=20
href=3D"mailto:phil.williams@toadmail.com">phil.williams@toadmail.com</A>=
>=20
wrote in message <A=20
href=3D"news:c3nco9$bq1$1@eclipse.org">news:c3nco9$bq1$1@eclipse.org</A>.=
...</DIV>To=20
follow Randy's mantra that I found several times in the =
newsgroup: =20
Copying and pasting are the domain of the model. Therefore, you =
must=20
implement your own actions that hook into the retarget actions. =
This is=20
exactly what I do in my application. I use the retarget action =
to call=20
my actions via the action IDs.<BR><BR>What I was wondering is why does =
GEF not=20
have a CutRetargetAction but does have the =
others.<BR><BR>Phil<BR><BR>Pratik=20
Shah wrote:<BR>
<BLOCKQUOTE cite=3Dmidc3n4kc$vl$1@eclipse.org type=3D"cite"><PRE =
wrap=3D"">CopyRetargetAction (for CopyTemplateAction) is not copying in =
the sense as
an
"Phil Williams" <A class=3Dmoz-txt-link-rfc2396E =
href=3D"mailto:phil.williams@toadmail.com"><phil.williams@toadmail.com=
></A> wrote in message
<A class=3Dmoz-txt-link-freetext =
href=3D"news:c3itcl$ou8$2@eclipse.org">news:c3itcl$ou8$2@eclipse.org</A>.=
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">Just wondering why there is =
Phil
</PRE></BLOCKQUOTE><PRE wrap=3D""><!---->
</PRE></BLOCKQUOTE></BLOCKQUOTE></BODY></HTML>
------=_NextPart_000_0252_01C4102A.B0463B00--
Re: CutRetargetAction missing [message #123695 is a reply to message #123645] |
Mon, 22 March 2004 19:41   |
--------------000206050804030400050905
Content-Type: text/plain; charset=us-ascii; format=flowed
I see said the blind man....
Thanks for the explaination!
Phil
> for the palette. And since the palette's static model is provided by
> GEF, they fall in the GEF domain. Like I said earlier, GEF uses those
> provide their own actions for copying/pasting/cutting anything in
> their model. And you don't HAVE to hook into the retarget actions
> provided by GEF. You should be able to create your own retarget
> actions and everything should work just fine. But why do that when we
> have these two lying around?
> <mailto:phil.williams@toadmail.com>> wrote in message
> newsgroup: Copying and pasting are the domain of the model.
> Therefore, you must implement your own actions that hook into the
> retarget actions. This is exactly what I do in my application. I
> use the retarget action to call my actions via the action IDs.
> but does have the others.
> Phil
> Pratik Shah wrote:
>>CopyRetargetAction (for CopyTemplateAction) is not copying in the sense as
>>selecting something in a logic diagram and copying it. It is there as an
>>>Thanks,
>>>Phil
Content-Type: text/html; charset=us-ascii
<html>
<head>
<title></title>
</head>
<body>
I see said the blind man....<br>
<br>
Thanks for the explaination!<br>
<br>
Phil<br>
<br>
Pratik Shah wrote:
<blockquote cite="midc3nlh4$mgp$1@eclipse.org" type="cite">
<title></title>
<meta http-equiv="Content-Type" content="text/html;charset=ISO-8859-1">
<meta content="MSHTML 6.00.2800.1400" name="GENERATOR">
<style></style>
<div>Reason for having copy/paste:<br>
provide their own actions for copying/pasting/cutting anything in their
model. And you don't HAVE to hook into the retarget actions provided
by GEF. You should be able to create your own retarget actions and
everything should work just fine. But why do that when we have these
two lying around?<br>
<br>
Reason for not having cut:<br>
You can't cut something from the palette.</div>
<div> </div>
<blockquote dir="ltr"
style="border-left: 2px solid rgb(0, 0, 0); padding-right: 0px; padding-left: 5px; margin-left: 5px; margin-right: 0px;">
<div>"Phil Williams" <<a href="mailto:phil.williams@toadmail.com">phil.williams@toadmail.com</a>>
wrote in message <a href="news:c3nco9$bq1$1@eclipse.org">news:c3nco9$bq1$1@eclipse.org</a>...</div>
is exactly what I do in my application. I use the retarget action to
call my actions via the action IDs.<br>
<br>
does have the others.<br>
<br>
Phil<br>
<br>
Pratik Shah wrote:<br>
<blockquote cite="midc3n4kc$vl$1@eclipse.org" type="cite">
<pre wrap="">CopyRetargetAction (for CopyTemplateAction) is not copying in the sense as
"Phil Williams" <a class="moz-txt-link-rfc2396E"
href="mailto:phil.williams@toadmail.com"><phil.williams@toadmail.com></a> wrote in message
<a class="moz-txt-link-freetext" href="news:c3itcl$ou8$2@eclipse.org">news:c3itcl$ou8$2@eclipse.org</a>...
</pre>
<blockquote type="cite">
<pre wrap="">Just wondering why there is a CopyRetargetAction, PasteRetargetAction,
Phil
</pre>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
</blockquote>
</blockquote>
</body>
</html>
--------------000206050804030400050905--
Re: CutRetargetAction missing [message #124514 is a reply to message #123645] |
Fri, 26 March 2004 10:29  |
------=_NextPart_000_0121_01C4131D.3B1E7E50
We should deprecate CopyRetargetAction and PasteRetargetAction. I don't =
know what they are doing, maybe the intention was for them to be on the =
toolbar??
"Pratik Shah" <ppshah@us.ibm.com> wrote in message =
news:c3nlh4$mgp$1@eclipse.org...
The copy/paste retarget actions that you see in GEF are used solely =
for the palette. And since the palette's static model is provided by =
GEF, they fall in the GEF domain. Like I said earlier, GEF uses those =
around?
To follow Randy's mantra that I found several times in the =
newsgroup: Copying and pasting are the domain of the model. Therefore, =
you must implement your own actions that hook into the retarget actions. =
This is exactly what I do in my application. I use the retarget action =
What I was wondering is why does GEF not have a CutRetargetAction =
Phil
as
an
Phil
=20
<STYLE></STYLE>
</HEAD>
<DIV><FONT face=3DArial size=3D2>We should deprecate CopyRetargetAction =
and=20
PasteRetargetAction. I don't know what they are doing, maybe the =
intention=20
was for them to be on the toolbar??</FONT></DIV>
<DIV>"Pratik Shah" <<A=20
href=3D"mailto:ppshah@us.ibm.com">ppshah@us.ibm.com</A>> wrote in =
message <A=20
href=3D"news:c3nlh4$mgp$1@eclipse.org">news:c3nlh4$mgp$1@eclipse.org</A>.=
...</DIV>
that you=20
palette's=20
static model is provided by GEF, they fall in the GEF domain. =
Like I=20
said earlier, GEF uses those actions for accessibility purposes only: =
to copy=20
something from the palette and then paste it in the diagram (hence, an =
clients=20
still have to provide their own actions for copying/pasting/cutting =
anything=20
in their model. And you don't HAVE to hook into the retarget =
actions=20
provided by GEF. You should be able to create your own retarget =
actions=20
and everything should work just fine. But why do that when we =
have these=20
two lying around?<BR><BR>Reason for not having cut:<BR>You can't cut =
something=20
from the palette.</DIV>
>=20
...</DIV>To=20
newsgroup: =20
you must=20
implement your own actions that hook into the retarget =
actions. This=20
is exactly what I do in my application. I use the retarget =
action to=20
call my actions via the action IDs.<BR><BR>What I was wondering is =
why does=20
GEF not have a CutRetargetAction but does have the=20
others.<BR><BR>Phil<BR><BR>Pratik Shah wrote:<BR>
the sense as
an
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">Just wondering why there =
Phil
</PRE></BLOCKQUOTE></BLOCKQUOTE></BLOCKQUOTE></BODY></HTML >
------=_NextPart_000_0121_01C4131D.3B1E7E50--
Current Time: Tue Jun 24 10:53:03 EDT 2025
Powered by FUDForum. Page generated in 0.27777 seconds
