Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Minimal SWT Console App(How to write a correct threaded SWT application)
Minimal SWT Console App [message #1235324] Thu, 23 January 2014 23:01 Go to next message
I'm trying to convert a batch command line program so it has a minimal SWT GUI, and this is my first SWT program. I have however been writing Java since 1996 and Eclipse since 2001 (WSAD4) and was team lead for IBM's first ever Java-based product. Now blissfully retired. This present application is a labor of love, and I possibly might open-source it if I can get some issues like this sorted out.
So I looked everywhere for an example of a "console" application in SWT, but could not find one. Eventually I learned about asyncExec and Runnables and a few other necessities, and came up with the following, but it clearly isn't correct. It does the job, with the Worker class representing the main body of my code, but the GUI window is locked while the application is writing to it. Only after the application is finished running can I move or size the window. At the end of the run the window does contain the correct data, but it might run for 5 or 10 minutes, and during that time I might want to move its window.
I'm sure I have missed something fundamental. I know I can move Eclipse's window while it is doing things in the background, so I need to replicate that ability (without thousands of loc).
Comments and suggestions appreciated.
public class Console2 {
	Display display;
	Shell shell;
	Text text;
	private void process() {
		display = new Display();
		shell = new Shell(display);
		shell.setLayout(new FillLayout());
		shell.setLocation(new Point(80, 80));
		text = new Text(shell, SWT.MULTI | SWT.V_SCROLL | SWT.READ_ONLY);
		shell.open();
		Display.getDefault().asyncExec(new Runnable() {
			public void run() {
				new Worker(text).work();
		while (!shell.isDisposed()) {
			if (!display.readAndDispatch())
				display.sleep();
		display.dispose();
	class Worker {
		Text text;
		public Worker(Text t) {
			text = t;
		void work() {
			for (int i = 0; i < 10000; i++) {
				if (!text.isDisposed()) {
					text.append("hello " + i + "\n");
		new Console2().process();
[Updated on: Thu, 23 January 2014 23:03] by Moderator
Re: Minimal SWT Console App [message #1235501 is a reply to message #1235324] Fri, 24 January 2014 09:18 Go to previous message
The asyncExec call invokes the run method on the Display thread. That means that the Display can't do anything until the run method returns. In your case the method doesn't return until the work method completes. Your work method would be considered a long running method. This means that that method should not be called from an asyncExec Runnable. The only piece of code that should be in the asyncExec Runnable is the isDisposed check and the text.append call. The rest of the work method needs to be executed in a separate Thread/Job.
Previous Topic:Spinner no setText
Next Topic:Compilation of HelloWorldSWT fails with "no swt-gtk-4333 in java.library.path"
Current Time: Mon Jul 21 04:16:32 EDT 2025
Powered by FUDForum. Page generated in 0.07518 seconds
