| Export feature wizard deletes my own build.xml file [message #123248] |
Fri, 05 September 2003 13:34  |
Originally posted by: jmordax.terra.es
I had a problem with automatic feature export. The problem (as I posted
a couple of posts above) is that I like to export all the content of the
help plugins packaged within a doc.zip file. And I haven't found a way
to say this within the buil.properties file.
So I have generated automatically the ANT script for this plugin and
modified to do what I want. Then I added the porpertie custom=true
within build.properties file to let know Eclipse that it has to execute
my build.xml file.
And now I export the feature and all plugins are exported perfectly,
including the help plugin.
Problem? I don't know why the export wizard removes my build.xml file.
So each time I have to create it.
Is this a known problem? Or I am missing another propertie similar to
custom=true to avoid my build.xml file to be deleted.
Thanks in advance,
Chemi.
FUDForum. Page generated in 0.04182 seconds
