Home » Modeling » Papyrus » CSS Themes(Get current theme and listen to theme changes)
CSS Themes [message #1234974] Thu, 23 January 2014 04:07 Go to next message
Hello Community,
the subtitle show it up:
My aim is it to find out (from source code), which CSS Theme is the current selected one (Very important is just: "No theme" or NOT "No theme"). Second aim is to add a listener to CSSTheme-Change, if it is possible.
I tried out accessing the specific information from preferences, but without success. Have you an idea or it is possible?
Thanks in advice Smile
Best regards, Erik
Re: CSS Themes [message #1236531 is a reply to message #1234974] Mon, 27 January 2014 07:47 Go to previous message
Hi Erik,
We have an example in the CSS properties view ({oep}.infra.gmfdiag.css.properties). We use the following "PreferenceObservableValue", which implements the JFace IObservableValue for an IPreferenceStore:
org.eclipse.papyrus.views.properties.observable.PreferencesObservableValue (From {oep}.views.properties)
IPreferenceStore store = new ScopedPreferenceStore(InstanceScope.INSTANCE, storeName);
IObservableValue preferenceObservable = new PreferencesObservableValue(propertyPath, store);
preferenceObservable.addChangeListener(listener);
Object currentValue = preferenceObservable.getValue()
The Observable returns a String value (Which is the ID of the CSS Theme). You can retrieve the Theme object with the following code:
String themeID = (String)preferenceObservable.getValue();
Theme theme = ThemeManager.instance.getTheme(themeID);
if (theme == ThemeManager.EmptyTheme.instance){
	//Do something
Camille
Previous Topic:Parametric Diagram in Papyrus 0.10
Next Topic:Papyrus in SpringSource Tool Suite Not Working
Current Time: Fri Jul 25 23:00:10 EDT 2025
Powered by FUDForum. Page generated in 0.04416 seconds
