Re: Modify the node in a TreeField [message #1233649 is a reply to message #1232668] |
Mon, 20 January 2014 02:30   |
Hi Marco,
hm... that's strange. I took our demo widget app (http://wiki.eclipse.org/Scout/Demo#Widgets) and added a listener to the tree as well:
@Order(10.0)
public class TreeField extends AbstractTreeField {
protected int getConfiguredGridH() {
return 5;
protected String getConfiguredLabel() {
return TEXTS.get("TreeField");
protected void execInitField() throws ProcessingException {
Tree exampleTree = new Tree();
AbstractTreeNode node1 = new AbstractTreeNode() {
protected void execDecorateCell(Cell cell) {
cell.setText("Node 1");
AbstractTreeNode node2 = new AbstractTreeNode() {
cell.setText("Node 2");
AbstractTreeNode node11 = new AbstractTreeNode() {
cell.setText("Node 1.1");
AbstractTreeNode node12 = new AbstractTreeNode() {
cell.setText("Node 1.2");
AbstractTreeNode node13 = new AbstractTreeNode() {
cell.setText("Node 1.3");
AbstractTreeNode node21 = new AbstractTreeNode() {
cell.setText("Node 2.1");
AbstractTreeNode node211 = new AbstractTreeNode() {
cell.setText("Node 2.1.1");
AbstractTreeNode node2111 = new AbstractTreeNode() {
cell.setText("Node 2.1.1.1");
exampleTree.addChildNode(exampleTree.getRootNode(), node1);
exampleTree.addChildNode(exampleTree.getRootNode(), node2);
exampleTree.addChildNode(node1, node11);
exampleTree.addChildNode(node1, node12);
exampleTree.addChildNode(node1, node13);
exampleTree.addChildNode(node2, node21);
exampleTree.addChildNode(node21, node211);
exampleTree.addChildNode(node211, node2111);
setTree(exampleTree, false);
getTree().addTreeListener(new TreeAdapter() {
public void treeChanged(TreeEvent e) {
super.treeChanged(e);
if (e.getType() == TreeEvent.TYPE_NODE_CLICK) {
MessageBox.showOkMessage("", "", "User clicked on " + e.getNode().getCell().getText());
@Order(10.0)
public class Tree extends AbstractTree {
Whenever I click on a node of the tree, the MessageBox will be opened.
Maybe you can post the complete code of your form. I will be happy to review it.
Matthias
Re: Modify the node in a TreeField [message #1234592 is a reply to message #1234286] |
Wed, 22 January 2014 05:23   |
Hi marco,
sure this is possible. However the API does not allow you to do this in 1 step, because by default the new row is always added at the end of the table.
The key method is the following, which allows to move a row in table
getTable().moveRow(int sourceIndex, int targetIndex)
Here is the idea:
1) Add a context menu to the table
2) When the user makes a rightclick on one of the rows, insert a new row
3) We know what element was selected in the table and therefore we can move the new row (at the end of the table) to this position
Here is a code snippet I just created (the MyTableMenu is inside the Table class):
@Order(10.0)
public class MyTableMenu extends AbstractMenu {
protected boolean getConfiguredEmptySpaceAction() {
return true;
protected String getConfiguredText() {
return "New Line";
protected void execAction() throws ProcessingException {
ITableRow newRow = getEditableTableField().getTable().addRowByArray(new Object[]{getEditableTableField().getTable().getCompanyNrColumn().getValues().length + 1, "New Company", ""});
ITableRow selectedRow = getEditableTableField().getTable().getSelectedRow(); //this is the row where we made the rightclick
if (selectedRow != null) { //okay, insert after selected row
int selectedRowIndex = selectedRow.getRowIndex();
int newRowsindex = newRow.getRowIndex();
if (newRowsindex < getEditableTableField().getTable().getRowCount()) {
getEditableTableField().getTable().moveRow(newRowsindex, selectedRowIndex + 1); //move to the next position after the selected row
Hope this helps. If you have any further questions, let us know. We are happy to help you!
Matthias
Attachment: table.png
(Size: 46.47KB, Downloaded 246 times)
FUDForum. Page generated in 0.30503 seconds
