Home » Modeling » EMF » Why code shows class as interface
Why code shows class as interface [message #1232843] Fri, 17 January 2014 17:11 Go to next message
I have created a simple model with a single class. Set abstract to false and interface to false. When I run the genmodel plugin for creating the model the java code creates the source of it being an interface.
* @see org.coughlin.grocerylist.grocerylist.GrocerylistPackage#getGrocerylist()
* @model interface="true" abstract="true"
* @generated
public interface Grocerylist extends Activity {
Based on my model I would expect it to say
public class Grocerylist extends Activity {
I do not understand why it says it is an interface
Re: Why code shows class as interface [message #1233798 is a reply to message #1232843] Mon, 20 January 2014 09:07 Go to previous messageGo to next message
As I am new to this forum not sure if this question belongs here. Thought it would be a relatively easy question that would get a quick response. If more information is needed let me know.
Re: Why code shows class as interface [message #1233835 is a reply to message #1233798] Mon, 20 January 2014 10:57 Go to previous messageGo to next message
Classes are generated in the impl package. By default EMF always generates an interface and a class for EClass defined in your model.
I think you can disable to behaviour and only generate classes by setting the option "Suppress Interfaces" in the genmodel. However, I don't really see a good reason to do that...
Re: Why code shows class as interface [message #1240923 is a reply to message #1233798] Fri, 07 February 2014 03:30 Go to previous message
Byron,
I've been away on vacation until today...
If you see
in your generated model's interface, it must be the case that your Ecore
model for Grocerylist has those properties set that way.
As Cedric suggests, you should always expect to see both a generated
interface and a generated implementation class (unless you suppress that
behavior, which is not generally such a good idea and certainly won't
allow you to model multiple inheritance)...
> Thanks
Previous Topic:assign value to model element automatically
Next Topic:Resolve platform:/resources outside the platform
Current Time: Sun Oct 26 02:27:35 EDT 2025
Powered by FUDForum. Page generated in 0.05558 seconds
