Resolve platform:/resources outside the platform [message #1233693] |
Mon, 20 January 2014 04:47  |
I have a case where I load a platform:/resource uri which contains
references to other platform:/resource models, but those models are not
available in the workspace, so when accessing these references, I get
proxy objects.
However, I have a way of locating those resources externally.
Is there a good way where I can hook into the resolution for
platform:/resource uris to import missing projects dynamically?
Re: Resolve platform:/resources outside the platform [message #1240930 is a reply to message #1234549] |
Fri, 07 February 2014 03:38  |
Felix,
If you know "ahead of time" which things you want to redirect, you can
always use the resource set's URI converter's URI map to redirect
platform:/resource/<project> to some other URI that represents the
location of that project.
On 22/01/2014 9:36 AM, Felix Dorner wrote:
> Hey,
> > Within your own application you can play games with ResourceSet
> locators.
> You mean
> http://download.eclipse.org/modeling/emf/emf/javadoc/2.8.0/org/eclipse/emf/ecore/resource/impl/ResourceSetImpl.ResourceLocator.html
> These look good. Unfortunately I'm on EMF 2.6 :(. But thanks very much
> for pointing it out.
> I can't change the file extensions either, nor use a custom protocol.
> The only way I can think of solving my problem is to find a hook in
> the API where, right before the URIHandler opens the stream, I locate
> my project in the environment (Basically I have to search , in a set
> of directories outside the workspace root) and import it. Then the
> URIHandler continues as if the project had always been in the
> workspace. Maybe the only solution is to use a high-priority
> customized PlatformResourceURIHandler (High-priority by adding it
> before any of the built-in resource handlers).
> Felix
FUDForum. Page generated in 0.03332 seconds
