Home » Eclipse Projects » EclipseLink » Add entities programmatically
Add entities programmatically [message #1233653] Mon, 20 January 2014 02:50 Go to next message
Hey all,
with hibernate i can add entities programmatically this way:
sessionFactory = new AnnotationConfiguration()
 .addPackage("test.animals")
 .addAnnotatedClass(Flight.class)
 .addAnnotatedClass(Sky.class)
Is there something similar in EclipseLink?
This question is often asked but i could not find a satisfing answer. One answer said Dynamic JPA could be a solution but the description says:
"map relational tables to virtual classes which are created dynamically at runtime"
My classes are not created dynamically, they are already existing, but have to be registered at the entityManager.
Thanks for any help in advance,
Thomas
Re: Add entities programmatically [message #1234628 is a reply to message #1233653] Wed, 22 January 2014 07:17 Go to previous messageGo to next message
Hey all,
ok maybe i try to ask another way:
I have a persistence bundle "P" which contains my JPA persistence.xml and of course a persistence service using an EntityManager to persist and load data from my database.
In addition i have two bundles "A" and "B" which contain JPA annotated pojos which i want to store.
How can i register the classes of bundle "A" and "B" at the entitymanager without having them defined in the persistence.xml which would crash the modularity of my application.
Note that i´m using EclipseLink.
Thanks alot for all advices, hints and so on.
Greetz
Thomas
Re: Add entities programmatically [message #1234809 is a reply to message #1234628] Wed, 22 January 2014 16:39 Go to previous messageGo to next message
How about composite PersistenceUnit ?
Re: Add entities programmatically [message #1234976 is a reply to message #1234809] Thu, 23 January 2014 04:14 Go to previous messageGo to next message
As i understood the composite persistence unit is mainly for using different database. The requirement to define the Plugins (or more concrete: jar files) "A" and "B" in the composite persistence unit crushes the modulartiy again...
Anyway thanks for the hint.
Re: Add entities programmatically [message #1235150 is a reply to message #1234976] Thu, 23 January 2014 12:14 Go to previous message
Yes, you can dynamically change the persistence unit using a metadata source to add in what is needed: http://wiki.eclipse.org/EclipseLink/Examples/JPA/MetadataSource
With this, you can define your own Metadata source that can return your classes from outside the persistence unit. The metadata source is akin to an orm.xml file and is processed about the same time, so you would only need to list the classes and they will then get processed regularly.
This feature ships with an implementation that will load orm.xml files, but I have seen others post more dynamic implementations I just don't have any links or examples handy.
Previous Topic:Got PropertyException when using MOXy
Next Topic:MismatchedTokenException
Current Time: Wed Jul 23 15:35:58 EDT 2025
Powered by FUDForum. Page generated in 0.04284 seconds
