Home » Language IDEs » Java Development Tools (JDT) » Cannot debug
Cannot debug [message #122943] Sat, 29 November 2003 13:23 Go to next message
hi,
when i try to debug i receive the following meesage:
Exception occured during launch
Reason:
Cannot connect to VM.
and this one in console:
Transport dt_socket failed to initialize, rc = 509.
FATAL ERROR in native method: No transports initialized
JVMDG217: Dump Handler is Processing a Signal - Please Wait.
JVMDG303: JVM Requesting Java core file
JVMDG304: Java core file written to
/home/text_replaced/javacore.20031129.201843.18754.txt
JVMDG215: Dump Handler has Processed Error Signal 6.
I'm using eclipse2.1.2(linux, gtk version), Fedora Linux and
IBMJava2-SDK-1.4.1-0.0.
Any idea?
Re: Cannot debug [message #123281 is a reply to message #122943] Mon, 01 December 2003 09:13 Go to previous messageGo to next message
Does the same problem happen with a different VM?
Darin
"a" <afilip@aut.utt.ro> wrote in message news:bqao7n$pd1$1@eclipse.org...
> hi,
> Reason:
> Any idea?
Re: Cannot debug [message #123320 is a reply to message #123281] Mon, 01 December 2003 09:57 Go to previous message
I've found the answer.
I think is something related with java and kernel, not with eclipse.
I remembered that in order to run java from www.blackdown.org on Redhat
Linux 9.0 I had to do this:
export LD_ASSUME_KERNEL=2.4.1
Now is working.
Previous Topic:Bind QuickFix to keystroke
Next Topic:Sheet/quick reference over key-bindings/mappings
Current Time: Fri Nov 07 00:03:48 EST 2025
Powered by FUDForum. Page generated in 0.03081 seconds
