conceptual question: "file download link"? [message #123318] |
Fri, 27 February 2009 06:40  |
Folks;
maybe I'm a little off track here, but using RAP I am at the moment trying
to achieve something pretty common in "ordinary" web user interfaces: In
some place (like the cell of a TableViewer) I want to place a functionality
to do a straightforward file download. There's a file provider servlet in
another application somewhere out in our system, and usually I can refer to
(and actually download) arbitrary files via HTTP using this servlet... the
only problem I see so far: How to "emulate" this feature (an HTML hyperlink
that makes the browser access an arbitrary HTTP ressource outside the RAP
context) in a RAP user interface? Ideas, anyone?
TIA and all the best,
Kristian
Re: conceptual question: "file download link"? [message #123496 is a reply to message #123447] |
Mon, 02 March 2009 10:06  |
Hi Rüdiger;
and first off, thanks a bunch for your thoughts on that.
Rüdiger Herrmann schrieb:
> as of now, there is no "download widget" or similar in RAP.
> The browser widget with a mini HTML page that contains only a link is
> probably the quickest workaround.
Well this is sort of what I intended to do... Eventually all that is
required in my use case so far would be a hyperlink (like used in the
RCP/IDE or in the RAP mail demo to display the e-mail address) referring to
an HTTP ressource outside the actual RAP application, maybe something like
Eclipse Forms' Hyperlink. Custom "download widget" would be a second option
to consider, I guess...
Cheers & thanks again,
Kristian
FUDForum. Page generated in 0.07070 seconds
